Multi Gigabit Switches
DMS-3130-30PS
16 100M/1/2.5GBase-T PoE ports, 8 100M/1/2.5/5GBase-T 60W PoE ports, 2 100M/1/2.5/5/10GBaseT ports, and 4 10/25G SFP28 ports L3 Stackable Managed Switch
DMS-3130-30TS
24 100M/1/2.5GBase-T ports, 2 100M/1/2.5/5/10GBase-T ports, and 4 10/25G SFP28 ports L3 Stackable Managed Switch
DMS-1250-12TP
Multi-Gigabit Smart Switch with 8-port 2.5GBase-T PoE + 2-port 10GBase-T and 2-port SFP+
DMS-1250-10SP
Multi-Gigabit Smart Switch with 8-port 2.5GBase-T PoE and 2-port SFP+
DMS-1250-10SPL
DMS-1250-10S
Multi-Gigabit Smart Switch with 8-port 2.5GBase-T and 2-port SFP+
DMS-1100-10TP
Switch with 8 2.5GBASE-T PoE ports and 2 10G SFP+ ports
DMS-1100-10TS
Switch with 8 2.5GBASE-T ports and 2 10G SFP+ ports
DMS-108P
8-Port Multi-Gigabit Unmanaged PoE Switch
DMS-108
8-Port Multi-Gigabit Unmanaged Switch
DMS-107
7-Port Multi-Gigabit Unmanaged Switch
DMS-106XT
6-Port Multi-Gigabit Configurable Switch with DIP Switch
DMS-105
5-Port Multi-Gigabit Unmanaged Switch
Industrial switches
DIS-100E-8W
Industrial Configurable Switch with 8 100Base-TX Ports and DIP Switch
DIS-100G-5PSW
Industrial Unmanaged Switch with 4 10/100/1000Base-T PoE Ports and 1 1000Base-X SFP Port
DIS-100G-8W
Industrial Configurable Switch with 8 1000Base-T Ports and DIP Switch
DIS-200G-12S
Layer 2 Industrial Managed Switch with 10 10/100/1000Base-T Ports and 2 1000Base-X SFP Ports
DIS-200G-12PS
Layer 2 Industrial Managed Switch with 10 10/100/1000Base-T Ports (8 PoE Ports) and 2 1000Base-X SFP Ports
DIS-210G-06
Layer 2 Industrial Managed Switch with 4x10/100/1000Base-T Ports and 2x1000Base-X SFP Ports
DIS-210G-06P
Layer 2 Industrial Managed Switch with 4x10/100/1000Base-T PoE Ports and 2x1000Base-X SFP Ports
DIS-210G-12
Layer 2 Industrial Managed Switch with 8x10/100/1000Base-T Ports and 4x1000Base-X SFP Ports
DIS-210G-12UP
Layer 2 Industrial Managed Switch with 6x10/100/1000Base-T 802.3at PoE Ports, 2x10/100/1000Base-T 802.3bt/UPoE Ports and 4x1000Base-X SFP Ports
DIS-210G-12P
Layer 2 Industrial Managed Switch with 8x10/100/1000Base-T PoE Ports and 4x1000Base-X SFP Ports
DIS-310G-24X
Layer 3 Industrial Managed Switch with 16x10/100/1000Base-T Ports, 4x1000Base-X SFP Ports and 4x10GBase-X SFP+ Ports
Fast Ethernet unmanaged desktop switches
DES-1005C
5-Port 10/100Base-TX Switch
DES-1005C/F6
5-Port 10/100 Mbps Unmanaged Switch
DES-1005C-CN
DES-1008C
8 Port SOHO Desktop Switch
DES-1008C/С
8-Port 10/100Base-TX Switch
DES-1008C/F6
8-Port 10/100 Mbps Unmanaged Switch
DES-1008C-CN
DES-1008D
8-Port 10/100Mbps Unmanaged Switch
DES-1016A
16-port 10/100 Switch
DES-1024A
24 Port 10/100 Switch
DGS-1005A/G
5-Port 10/100/1000 Mbps Unmanaged Switch
DGS-1005D
5-Port 10/100/1000Base-T Switch
DGS-1005P
5-Port Gigabit Switch with 4 PoE Ports
DGS-1008A
8-Port Gigabit Easy Desktop Switch
DGS-1008D
8-Port 10/100/1000Base-T Switch
DGS-1008P
8-Port Gigabit Unmanaged Desktop PoE Switch
Gigabit Ethernet 19" rackmount switches
DES-1016D
Unmanaged Switch with 16 10/100Base-TX ports
DES-1024D
Unmanaged Switch with 24 10/100Base-TX ports
DGS-1008MP
8-Port PoE Desktop Switch
DGS-1010MP
10-Port Gigabit PoE Switch
DGS-1024C
24-Port 10/100/1000 Mbps Unmanaged Switch
DGS-1024C/F6
DGS-1026MP
26-Port Unmanaged Gigabit PoE Switch
DGS-1052
48 Ports 10/100/1000Mbps + 4 Ports Combo 1000Base-T/SFP Unmanaged Switch
Конфигурируемые коммутаторы Fast/Gigabit Ethernet, монтируемые в 19" стойку
DES-1018MPV2
Configurable Switch with 16 100Base-TX PoE Ports, 2 Combo 1000Base-T/SFP Ports and DIP Switch
DGS-1010P
Configurable Switch with 8 1000Base-T PoE Ports, 2 1000Base-X SFP Ports and DIP Switch
DGS-1016D
16-Port Configurable Gigabit Switch with DIP Switch
DGS-1018P
Configurable Switch with 16 1000Base-T PoE Ports, 2 1000Base-X SFP Ports and DIP Switch
DGS-1024D
24-Port Configurable Gigabit Switch with DIP Switch
DGS-1026P
Configurable Switch with 24 1000Base-T PoE Ports, 2 1000Base-X SFP Ports and DIP Switch
Smart Switches Fast/Gigabit Ethernet series EasySmart
DGS-1100-05PDV2
EasySmart managed switch with 5 10/100/1000Base-T ports (1 PD port and 2 PSE ports)
DGS-1100-05V2
DGS-1100-08PLV2
EasySmart managed switch with 8 10/100/1000Base-T ports (4 ports with PoE support)
DGS-1100-08PV2
8-Port 10/100/1000 Mbps (PoE) Smart Managed Switch
DGS-1100-08V2
DGS-1100-10MPPV2
8 x 10/100/1000Base-T PoE ports + 2 x 1000Base-X SFP ports EasySmart switch
DGS-1100-10MPV2
DGS-1100-16V2
Smart Managed Switch with 16 x 10/100/1000Base-T Ports
DGS-1100-18PV2
16 x 10/100/1000Base-T PoE ports + 2 x combo 1000Base-T/SFP ports EasySmart switch
DGS-1100-24V2
Smart Managed L2 Switch with 24 x 10/100/1000Base-T Ports
DGS-1100-26MPPV2
24 x 10/100/1000Base-T PoE ports + 2 x combo 1000Base-T/SFP ports EasySmart switch
DGS-1100-26MPV2
DSS-200G-10MP
8 Port 10/100/1000 Mbps + 2 Port SFP 1000 Mbps PoE switch
DSS-200G-10MPP
DSS-200G-28MP
24 Port 10/100/1000 Mbps + 4 Port Combo 1000Base-T/SFP PoE switch
DSS-200G-28MPP
Fast/Gigabit (Green) Ethernet Web Smart Switches
DGS-1210-08P
L2 Managed Switch with 8 x 10/100/1000Base-T Ports and 2 x 1000Base-X SFP Ports (8 x PoE 802.3af/at, 65W PoE Budget)
DGS-1210-10MP
Web Smart Switch with 8 10/100/1000Base-T PoE ports and 2 1000Base-X SFP ports
DGS-1210-10P
Smart Managed Switch with 8 10/100/1000Base-T PoE Ports and 2 1000Base-X SFP Ports
DGS-1210-16
Web Smart Switch with 16 10/100/1000Base-T and 4 100/1000Base-T/SFP combo ports
DGS-1210-20
DGS-1210-26
Web Smart Switch with 24 10/100/1000Base-T ports and 2 1000Base-X SFP ports
DGS-1210-28
Smart Managed Switch with 24 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports
DGS-1210-28MP
Smart Managed Switch with 24 10/100/1000Base-T PoE Ports and 4 100/1000Base-T/SFP Combo Ports
DGS-1210-28P
DGS-1210-52
Smart Managed Switch with 48 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports
10 Gigabit Ethernet Smart Switches
DXS-1210-12TC
10G Smart Switch with 8-port 10GBase-T and 2-port 10G SFP+ and 2-port 10GBase-T/SFP+ combo port
DXS-1210-16TC
10G Smart Switch with 12-port 10GBase-T and 2-port 10G SFP+ and 2-port 10GBase-T/SFP+ combo port
Fast/Gigabit Ethernet managed standalone L2/L3 switches
DES-3200-28
Layer 2 Management Switch with 24 ports 10/100 Base-TX + 2 ports 100/1000 SFP + 2 Combo ports 10/100/1000 BASE-T/ 100/1000 SFP
DGS-1100-10/ME
Managed L2 Metro Ethernet Switch
DGS-1210-10/ME
L2 Managed Switch with 8 10/100/1000Base-T Ports and 2 1000Base-X SFP Ports
DGS-1210-10P/FL
8 10/100/1000Base-T PoE Ports and 2 1000Base-X SFP Ports L2 Managed Switch
DGS-1210-10MP/FL
DGS-1210-10MP/RU/FL
Управляемый L2 коммутатор с 8 портами
DGS-1210-10P/ME
10/100/1000BASE-T PoE + 2 1G SFP Ports L2 Management Switch
DGS-1210-10XS/ME
Managed L2 Switch with 8 x 100/1000Base-X SFP ports and 2 x 10GBase-T/SFP+ combo ports
DGS-1210-20/FL
16 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
DGS-1210-20/ME
16 10/100/1000BASE-T + 4 1G SFP Ports L2 Management Switch
DGS-1210-28/RU
Управляемый L2 коммутатор с 24 портами 10/100/1000Base-T и
DGS-1210-28/FL
24 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
DGS-1210-28/RU/FL
DGS-1210-28P/FL
24 10/100/1000Base-T PoE Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
DGS-1210-28MP/FL
DGS-1210-28/ME
L2 Managed Switch with 24 10/100/1000Base-T Ports and 4 1000Base-X SFP Ports
DGS-1210-28P/ME
24 10/100/1000BASE-T PoE + 4 1G SFP Ports L2 Management Switch
DGS-1210-28XS/ME
24 100/1000 Mbps SFP + 4 10G SFP+ Ports L2 Management Switch
DGS-1210-52MP/FL
48 10/100/1000Base-T PoE Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
DGS-1210-52/ME
48 10/100/1000BASE-T+ 4 1G SFP Ports L2 Management Switch
DGS-1210-52P/ME
Metro Ethernet Managed Switch with 24 10/100/1000Base-T PoE ports, 24 10/100/1000Base-T ports and 4 1000Base-X SFP ports
DGS-1210-52MP/ME
L2 Managed Switch with 48 10/100/1000Base-T PoE ports and 4 1000Base-X SFP ports
DGS-1210-52MPP/ME
Metro Ethernet Managed Switch with 48 10/100/1000Base-T PoE ports and 4 1000Base-X SFP ports
DGS-1250-28X
24 Ports 10/100/1000 Mbps + 4 Ports 10G SFP+ L2 Managed Switch
DGS-1250-52X
48 Ports 10/100/1000 Mbps + 4 Ports 10G SFP+ L2 Managed Switch
DGS-3000-10L
8 10/100/1000Base-T ports + 2 1000Base-X SFP ports L2 Managed Switch
DGS-3000-28L
24 10/100/1000Base-T ports + 4 1000Base-X SFP ports L2 Managed Switch
DGS-3000-28XMP
24 10/100/1000Base-T PoE ports + 4 10GBase-X SFP+ ports L2 Managed Switch
DGS-3000-52L
48 10/100/1000Base-T ports + 4 1000Base-X SFP ports L2 Managed Switch
Управляемые коммутаторы Gigabit Ethernet уровня 3
DGS-1250-28X/RU
Управляемый L3 коммутатор c 24 портами 10/100/1000Base-T и 4 портами 10GBase X SFP+
DGS-1250-28XMP/RU
DGS-1250-52X/RU
Управляемый L3 коммутатор c 48 портами
DGS-1250-52XMP/RU
Управляемый L3 коммутатор с
Managed Stackable Switches Fast/Gigabit Ethernet Layer 2+
DGS-1510-28X
L2+ Stackable Managed Switch with 24 10/100/1000Base-T Ports and 4 10GBase-X SFP+ Ports
DGS-1510-28XMP
L2+ Stackable Managed Switch with 24 10/100/1000Base-T PoE Ports and 4 10GBase-X SFP+ Ports
DGS-1510-28P
L2+ Stackable Managed Switch with 24 10/100/1000Base-T PoE Ports, 2 1000Base-X SFP Ports and 2 10GBase-X SFP+ Ports
DGS-1510-52X
L2+ Stackable Managed Switch with 48 10/100/1000Base-T Ports and 4 10GBase-X SFP+ Ports
DGS-1510-52XMP
L2+ Stackable Managed Switch with 48 10/100/1000Base-T PoE Ports and 4 10GBase-X SFP+ Ports
Managed Stackable Switches Fast/Gigabit Ethernet Layer 3
DGS-1520-28
24-port 10/100/1000Base-T, 2-port 10GBase-T and 2-port 10G SFP+ Layer 3 Stackable Smart Managed Switch
DGS-1520-28MP
20-port 10/100/1000Base-T PoE, 4-port 2.5GBase-T PoE, 2-port 10GBase-T and 2-port 10G SFP+ Layer 3 Stackable Smart Managed Switch
DGS-1520-52
48-port 10/100/1000Base-T, 2-port 10GBase-T and 2-port 10G SFP+ Layer 3 Stackable Smart Managed Switch
DGS-1520-52MP
44-port 10/100/1000Base-T PoE, 4-port 2.5GBase-T PoE, 2-port 10GBase-T and 2-port 10G SFP+ Layer 3 Stackable Smart Managed Switch
DGS-3130-30PS
24 10/100/1000Base-T PoE ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable Managed Switch
DGS-3130-30S
24 1000Base-X SFP ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
DGS-3130-30TS
24 10/100/1000Base-T ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
DGS-3130-54S
48 1000Base-X SFP ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
DGS-3130-54S/B
48 1000Base-X SFP ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable Managed Switch
DGS-3130-54PS
48 10/100/1000Base-T PoE ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable Managed Switch
DGS-3130-54TS
48 10/100/1000Base-T ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
DGS-3630-28PC
20 10/100/1000BASE-T PoE ports + 4 Combo 10/100/1000BASE-T PoE/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch
DGS-3630-28SC
20 SFP ports + 4 Combo 10/100/1000BASE-T/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch with MPLS Image
DGS-3630-28TC
20 10/100/1000BASE-T ports + 4 Combo 10/100/1000BASE-T/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch with MPLS Image
DGS-3630-52PC
44 10/100/1000Base-T PoE ports + 4 Combo 10/100/1000Base-T PoE/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch
DGS-3630-52TC
44 10/100/1000BASE-T ports + 4 Combo 10/100/1000BASE-T/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch with MPLS Image
Managed Stackable Switches 10 Gigabit Ethernet Layer 3
DXS-3130-32S
L3 Stackable Managed Switch with 28 10GBase-X SFP+ Ports and 4 25GBase-X SFP28 Ports
DXS-3130-28P
L3 Stackable Managed Switch with 24 10GBase-T PoE Ports and 4 25GBase-X SFP28 Ports
DXS-3410-32SY
28 SFP+ Ports and 4 10/25G SFP28 Ports 10G L3 Stackable Managed Switch
DXS-3410-32XY
4 100M/1/2.5/10GBase-T Ports, 4 SFP+ Ports and 4 10/25G SFP28 Ports 10G L3 Stackable Managed Switch
Managed Stackable Switches 10/100G Gigabit Ethernet Layer 3
5000 Series Data Center Switches
DQS-5000-32Q28
32-port 100G QSFP28 interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
DQS-5000-32S
32-port 40G QSFP+ interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
DQS-5000-54SQ28
48-port 25G SFP28, 6-port 100G QSFP28 interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
DQS-5000-56ZS
48-port 25G SFP28, 8-port 40/100G QSFP28 L3 managed switch with 2 AC PSUs and 5 front-to-back fan modules
DXS-5000-54S
48-port 10G SFP+, 6-port 40G QSFP+ interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
Managed Layer 3 Modular Switch DGS-6600
DGS-6600-24SC2XS
12 SFP ports + 12 combo ports 10/100/1000Base-T/SFP and 2 10G SFP+ ports Module
DGS-6600-24SC2XS-C
12 ports GE SFP + 12 ports 10/100/1000Base-T/SFP Combo + 2 ports 10GE SFP+ Module with MPLS function
Модули для коммутаторов DGS-3400, DGS-3600, DGS-3610
GBIC / mini GBIC (SFP) tranceivers
DEM-210
SFP Transceivers 1 port 100Base-FX for singlemode fiber optic cable, power supply 3.3V (up to 15km)
DEM-310GT
1000Base-LX Single-Mode SFP transceiver (up to 10 km)
DEM-311GT
1000Base-SX Multi-Mode SFP transceiver (up to 550 m)
DEM-312GT2
1000Base-SX+ Multi-Mode SFP transceiver (up to 2 km)
DEM-330R
1000Base-BX-U Single-Mode WDM SFP transceiver (up to 3/10 km), Tx:1310 nm, Rx:1550 nm
DEM-330T
1000Base-BX-D Single-Mode WDM SFP transceiver (up to 3/10 km), Tx:1550 nm, Rx:1310 nm
DEM-331R
1000Base-BX-U (Tx:1310 nm, Rx:1550 nm) Single-Mode WDM SFP transceiver (up to 20/40 km)
DEM-331T
1000Base-BX-D (Tx:1550 nm, Rx:1310 nm) Single-Mode WDM SFP transceiver (up to 20/40 km)
DEM-410T
10GBase-T Copper SFP+ transceiver (up to 30 m)
DEM-436XT-BXD
10GBase-ER (Tx:1330 nm, Rx:1270 nm) Single-Mode WDM SFP transceiver (up to 40/20 km)
DEM-436XT-BXU
10GBase-ER Single-Mode WDM SFP+ transceiver (up to 40 km / 20km), Tx:1270 nm, Rx:1330 nm
DGS-703
1000Base-LX Single-Mode GBIC Transceiver (up to 10 km)
DGS-707
1000Base-SX Multi-Mode GBIC Transceiver (up to 550 m)
DGS-712
1000Base-T Copper SFP Transceiver (up to 100 m)
DIS-S330T
1000Base-BX-D (Tx:1550 nm, Rx:1310 nm) Single-Mode WDM SFP transceiver (up to 30 km)
XFP tranceivers
SFP28 tranceivers
DEM-S2801SR
25GBase-SR Multi-mode OM3 (70 m) / OM4 (100 m) SFP28 Transceiver
DEM-S2810LR
25GBase-LR Single-mode (10 km) SFP28 Transceiver
QSFP+ tranceivers
DEM-QX01Q-SR4
40GBase-SR4 Multi-mode OM3 (100 m) / OM4 (150 m) QSFP+ Transceiver
DEM-QX10Q-LR4
40GBase-LR4 Single-mode QSFP+ Transceiver (up to 10 km)
QSFP28 tranceivers
Cables
DEM-CB100Q28
Passive Copper 100G QSFP28 Direct Attach Cable, 1 m
DEM-CB100QXS-4XS
40G Passive QSFP+ Twinaxial Direct Attach Cable, 1m
DEM-CB300QXS
40G Passive QSFP+ Twinaxial Direct Attach Cable, 3m
DEM-CB700S
DEM-CB300S
10G Passive SFP+ Twinaxial Direct Attach Cable, 3m
DEM-CB100S
10G Passive SFP+ Twinaxial Direct Attach Cable, 1m
DEM-CB50
10G InfniBand Twinaxial Cable for connecting with CX4 devices, 50сm
Redundant Power Supply (RPS)
SNMP management software
D-View 8
D-View 8 Network Management Software
Remanufactured Equipment
DES-1210-28/ME_RFB
Metro Ethernet Switch with 24 10/100 Base-TX+ + 2 100/1000 SFP + 2 Combo 10/100/1000 Base-T/100/1000 SFP
DES-1228/ME
24-Port 10/100Mbps + 2 1000BASE-T + 2 Combo 1000BASE-T/SFP L2 MetroEthernet Switch
DES-3026
24 port 10/100 Switch + 2 Fiber/Gigabit Uplinks
DES-3028_RFB
24 10/100Base-TX ports + 2 1000Base-T ports + 2 Combo 1000Base-T/SFP ports L2 Managed Switch
DES-3200-28_RFB
24 10/100Base-TX ports + 2 100/1000Base-X SFP ports + 2 Combo 100/1000Base-T/SFP ports L2 Managed Switch
DES-3526
Managed 24-Port 10/100 Stackable L2 Switch, 2 Gigabit Copper Ports, 2 Combo SFP
DES-3528
Managed 24-Port 10/100 L2+ Switch, 4 Gigabit Copper Ports + 2 Combo SFP
