DIS-200G-12PSW
Industrial Managed L2 Switch with 10 x 10/100/1000Base-T Ports and 2 x 1000Base-X SFP Ports (8 x PoE 802.3af/at Ports, PoE Budget up to 240 W)
Description
The DIS-200G-12PSW Managed Switch is equipped with 10 10/100/1000Base-T ports (8 ports support Power over Ethernet (PoE)) and 2 1000Base-X SFP ports for high-speed uplink connections to the backbone. It is designed for use in industrial enterprise networks. The DIS-200G-12PSW supports D-Link Green technology and advanced management and security features. Management features include SNMP, Web-based management, and a Command Line Interface (CLI).
Rugged Design
The metal case (IP30 standard) and wide operating temperature range allow the DIS-200G-12PSW to be deployed in harsh environmental conditions. High electromagnetic compatibility ensures the switch's immunity to strong electromagnetic interference, while the passive cooling system ensures silent operation. The device can be wall-mounted, installed on a DIN rail, or mounted in a 19-inch rack using appropriate brackets (rack-mount brackets are not included).
6 kV surge protection ensures the copper ports' resistance to induced voltage and prevents damage to the switch and connected devices.
Reliability and Fault Tolerance
The DIS-200G-12PSW supports Ethernet Ring Protection Switching (ERPS, ITU-T G.8032) technology, which ensures minimal ring recovery time after a failure. To ensure maximum fault tolerance, the switch implements a dual power redundancy scheme: up to two independent DC1 power sources can be connected to the DIS-200G-12PSW, and a connector for an AC¹ power adapter is also provided.
Auto Surveillance VLAN
The DIS-200G-12PSW switch supports Auto Surveillance VLAN (ASV), making it an ideal solution for deploying video surveillance systems. This feature automatically detects video surveillance equipment in the general network and assigns it to a dedicated VLAN, within which video traffic is given the highest service priority. Auto Surveillance VLAN support ensures stable operation of video applications, high-quality transmission, and maximum protection of multimedia traffic regardless of the overall network load.
Easy Troubleshooting
The DIS-200G-12PSW switch supports cable diagnostics and Loopback Detection, enabling network administrators to quickly and easily identify and resolve network issues. The Loopback Detection feature is used to detect loops and automatically disable the port on which a loop is detected. The cable diagnostics feature is designed to determine the condition of the twisted pair cable as well as the type of cable fault.
Power over Ethernet
The 8 ports of this switch support the IEEE 802.3at PoE standard. The total PoE budget of the switch can reach up to 240 W, depending on the power of the connected power source. For example, when a DIS-PWR180AC power adapter with 180 W is connected, the PoE budget is 140 W; when a more powerful power source, such as 300 W, is connected, the PoE budget can reach up to 240 W, i.e., 30 W per port. Special indicators on the front panel of the device help monitor the utilized PoE budget.
1Not included in the package.
General features
Processor
• 416 MHz
RAM
• 128 MB
Flash Memory
• 32 MB
Interfaces
• 10 x 10/100/1000Base-T ports (8 ports with PoE support)
• 2 x 1000Base-X SFP ports
• Console port with RJ-45 connector
• Relay output 1 A / 24 V for power failure alarm
LEDs
• PWR 1/2/3
• ALM
• SYS
• Link/Activity/Speed (per port)
• PoE Status (per PoE port)
• PoE Power Budget
Buttons
• Reset
Power Connector
• DC: terminal block for connecting up to two independent power sources¹ (48 V to 54 V DC)
• AC: 4-pin power mini-DIN PD-40VS (for connecting power adapter¹ with PDP-40 plug)
Case
• Metal (IP30 standard)
Mounting
• DIN rail
Standards and Functions
• IEEE 802.3 10Base-T (twisted-pair copper)
• IEEE 802.3u 100Base-TX (twisted-pair copper)
• IEEE 802.3ab 1000Base-T (twisted-pair copper)
• IEEE 802.3z 1000Base-X
• IEEE 802.3x Flow Control
• Automatic MDI/MDIX detection on all copper ports
Functionality
Switching Fabric
• 24 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 8K entries
Max. Packet Forwarding Rate
• 17.85Mpps
Packet Buffer Size
• 512 KB
Jumbo frame
• 9600 bytes
Software
Layer 2 Features
• Flow Control
  - 802.3x
  - HOL Blocking Prevention
• IGMP Snooping
  - IGMP v1/v2
  - IGMP v3 awareness
  - Supports up to 256 groups (shared with MLD Snooping)
  - IGMP Snooping Querier
  - Port-based IGMP Snooping Fast Leave
• MLD Snooping
  - MLD v1
  - MLD v2 awareness
  - Supports up to 256 groups (shared with IGMP Snooping)
  - MLD Snooping Querier
  - Port-based MLD Snooping Fast Leave
• Link Aggregation
  - 802.3ad
  - Max. 6 groups per device/8 ports per group
• Supports Ethernet Ring Protection Switching (ERPS, ITU-T G.8032)
• Loopback Detection
• LLDP
• Port Mirroring
  - Supports 1 mirroring group
  - Modes: One-to-One, Many-to-One
• Statistics
  - Tx Ok
  - Tx Error
  - Rx Ok
  - Rx Error
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
VLAN
• 802.1Q Tagged VLAN
• VLAN на основе портов
• Auto Surveillance VLAN 2.0 (ASV2.0)
• Voice VLAN
• Asymmetric VLAN
• VLAN Groups
  - 128 VLAN groups
  - Max. 4094 VLANs
• GVRP
Quality of Service (QoS)
• CoS based on:
  - Switch port
  - 802.1p priority queues
  - ToS
  - IP Precedence
• Bandwidth Control
  - Port-based (ingress, with minimum granularity of 100 Kbit/s)
• Queue Handling
  - Strict Priority
  - Weighted Round Robin (WRR)
• 4 queues per port
Security
• D-Link Safeguard Engine
• Traffic Segmentation
• Broadcast/Multicast/Unicast Storm Control
• SSH
• DoS Attack Prevention
• SSL
• Port Security
OAM
• Cable Diagnostics
• DDM (Digital Diagnosics Monitoring)
AAA
• Web-based Access Control (WAC)
• RADIUS
Management
• Web interface (IPv4/IPv6 support)
• Command Line Interface (CLI)
• SNTP
• SNMP v1/v2c/v3
• SNMP Trap
• Telnet server
• Password encryption
• System Log
• DHCP Client
• TFTP Client
• LLDP
• D-Link Discovery Protocol (DDP)
• Multiple Software Version Support
Green Technology
• Power saving by:
  - Link status detection
  - LED shutdown
  - Port shutdown
  - Sleep mode
MIB/RFC Standards
• RFC768 UDP
• RFC791 IP
• RFC792 ICMP
• RFC793 TCP
• RFC826 ARP
• RFC1213 MIB II
• RFC1493 Bridage MIB
• RFC1907 SNMPv2 MIB
• RFC2668 802.3 MAU MIB
• RFC4133 Entity MIB
• RFC4363 IEEE 802.1p MIB
• ZoneDefense MIB
• Private MIB
PoE
PoE Standards
• IEEE 802.3af
• IEEE 802.3at
PoE-Enabled Ports
• Ports 1 to 8
PoE Mode
• 1-8 Ports: A mode
PoE Budget
• Up to 240 W (when a DIS-PWR180AC power adapter with 180 W is connected, the PoE budget is 140 W; when a more powerful power source, such as 300 W, is connected, the PoE budget can reach up to 240 W, max. 30 W per PoE port)
Physical/Environmental
Power
• 48–54 V DC (with the ability to connect up to two power sources (not included in the package))
• Power adapter (not included in the package):
  - Output: 54 V DC
Max Power Consumption
• PoE On: 260 W
• PoE Off: 10.8 W
Standby Power Consumption
• 7.02 W
Heat Dissipation
• PoE On: 887.16 BTU/hr
• PoE Off: 36.85 BTU/hr
MTBF
• 156,452 hours
Acoustic
• 0 dB
ESD protection
• Supports up to 6 kV on copper ports (compliant with IEC 61000-4-5)
Ventilation System
• Fanless
Temperature
• Operating: -40 ~ 75  °C
• Storage: -40 ~ 85 °C
Humidity
• Operating: 0 to 95% non-condensing
• Storage: 0 to 95% non-condensing
Dimensions
• 210x171.2x53mm
Weight
• 1.76kgs
Certifications
• RoHS
EMI
• CE
• FCC
• BSMI
• C-Tick
Safety
• UL
Certificates
Order info
DIS-200G-12PSW  Industrial Managed L2 Switch with 10 x 10/100/1000Base-T Ports and 2 x 1000Base-X SFP Ports (8 x PoE 802.3af/at Ports, PoE Budget up to 240 W)
Pictures
DIS-200G-12PSW/A1
Front view
View from the right
Left side view
Back view
Top view
Downloads
Support Resources
