DES-1008C/F6
8-Port 10/100 Mbps Unmanaged Switch
Description
The DES-1008C 10/100 Mbps Unmanaged Switch is economical, plug-and-play networking switch solutions for SOHO and small and medium businesses wanting to benefit from the increased bandwidth of Fast Ethernet. It provides 8 10/100 Mbps ports that enable you to easily expand your network and provide a quick way to upgrade your network to fast connectivity.
Conserve Energy
The DES-1008C implements 802.3az Energy Efficient Ethernet, which saves energy and reduces heat automatically without sacrificing performance or functionality. The switch can detect when a connected computer is shut down or when there is no Ethernet traffic, and will put the port in standby mode, saving a substantial amount of power. In addition, the switch optimizes power usage for each port for the length of cable connected to it, using only as much power as is required. Both of these features work together to help you save power automatically.
Reliable Plug and Play Installation
The DES-1008C is Plug-and-Play device that requires no configuration, so setup is simple and hassle-free, and you can easily connect multiple computers, share files, music, and video across your home or small office network, or even create a multiplayer gaming environment. 802.3x flow control on each port minimizes dropped packets when the port's receiving buffer is full, giving you a more reliable connection for all of your connected devices.
General features
Interfaces
• 8 x 10/100 Mbps LAN ports
LEDs
• Power (per device)
• Link/Activity (per port)
Port Standards & Functions
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3x Flow Control
• Auto MDI/MDIX crossover for all ports
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• Back pressure at half-duplex operation
• Auto-negotiation for each port
Data Transfer Rates
• Ethernet:
10 Mbps (half duplex)
20 Mbps (full duplex)
• Fast Ethernet:
100 Mbps (half duplex)
200 Mbps (full duplex)
Performance
Switching Capacity
• 1.6 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 2K entries
Maximum Packet Forwarding Rate
• 1.19 Mpps
RAM Buffer
• 96 KB per device
Jumbo Frame Size
• 2 048 byte
Physical Parameters
Dimensions (L x W x H)
• 132 x 53 x 21 mm
Weight
• 74.8 g
Power Input
• DC 5 V / 0.55 A
• DC jack: Located on side
Maximum Power Consumption
• 1.55 W
Standby Power Consumption
• 0.55 W
Heat Dissipation
• 0.2 W 0.691 BTU/hr
MTBF
• 1 579 582 hours
Acoustics
• 0 dB
Temperature
• Operating: 0 to 40 C
• Storage: -40 to 70 C
Humidity
• Operating: 10% to 90% (Non-condensing)
• Storage: 5% to 95% (Non-condensing)
Certifications
• CE Class B
• CE (LVD 2006/95/EC)
Certificates
Order info
DES-1008C/F6/E 8-Port 10/100 Mbps Unmanaged Switch
