DEM-312GT2
1000Base-SX+ Multi-Mode SFP transceiver (up to 2 km)
Description
The DEM-312GT2 Gigabit SFP fiber transceiver is external transceiver designed for insertion in SFP (Small Form-Factor Pluggable) slot of network device for transmission and reception of data signals on the fiber cables. This transceiver provides high-speed and reliable distance (up to 2 km) data transfer.
The DEM-312GT2 transceiver uses standard duplex LC connector for fiber cable connection. It conforms to industry standards and is interoperable with D-Link Gigabit switches. All D-Link transceivers are hot-pluggable. Hot-swap capability allows network administrators to plug or unplug it from the SFP slot without having to turn off the power of the connected device.
General features
 General features
 Standard
 • IEEE 802.3z 1000Base-SX+
 Wavelength
 • 1310 nm
 Data Rate
 • 1.25 Gbps
 Connector
 • Duplex LC
 Maximum Fiber Cable Length
 • 2 km
 Transmit Power Range
 • -8 to -15 dBm
 Receive Power Range
 • -3 to -20 dBm
 Sensitivity
 • -20 dBm
 Supported Features
 • Hot swap
• MSA compliant
• RoHS compliant
 Physical Parameters
 Power Support
 • 3.3 V
 Supply Current
 • 220 mA
 Temperature
 • Operating: 0° to 70°C
• Storage: -40° to 85°C
 Humidity
 • Operating: 0% to 85%
• Storage: 0% to 85%
 Dimensions
 • 55.4 mm x 13.7 mm x 8.5 mm
Certificates
Order info
DEM-312GT2/A1A 1000Base-SX+ Multi-Mode SFP transceiver (up to 2 km)
