DGS-1100-05V2
EasySmart managed switch with 5 10/100/1000Base-T ports
Description
The DGS-1100-05V2 switch is designed to meet the requirements of small, medium, and enterprise businesses. Advanced management features, a range of diagnostic and troubleshooting tools, and energy efficient technologies provide a flexible solution to meet your networking requirements.
D-Link Green/Power Saving Performance
Compliant with IEEE 802.3az Energy Efficient Ethernet, this switch consumes less energy by cutting down on power consumption when port utilization is low. By deploying compatible devices, users can cut operating costs and even cut down on necessary cooling equipment, helping small and medium-sized businesses stay within their budgets. The DGS-1100-05V2 also features D-Link Green Technology that helps to save energy automatically. The switch monitors the link status of every port and significantly reduces power consumption of the interface when there is no link or network traffic detected.
Easy to deploy
DGS-1100-05V2 switch supports D-Link Network Assistant (DNA) and a web-based management interface. The client-based D-Link Network Assistant (DNA) discovers all D-Link Smart Managed Switches within the same L2 network segment, making the initial setup quick and easy. This allows extensive switch configuration and basic administration of discovered devices, including password changes and firmware upgrades. The web-based interface provides a user-friendly way for network administrators to manage the switch down
to the port level. The interface can be accessed from a web browser, allowing the switches to be controlled from any PC that is connected to the network.
Surveillance VLAN and Bandwidth Control
The DGS-1100-05V2 supports Surveillance VLAN for IP surveillance deployments. This gives video traffic a dedicated VLAN and higher priority through the switch, separating surveillance traffic from the rest of the network. This ensures security and guarantees the quality of the video traffic, sparing businesses the added cost of dedicated surveillance hardware. Bandwidth Control can reserve bandwidth on a per-port basis for important functions that require larger bandwidth or have higher priority.
Easy Troubleshooting
The DGS-1100-05V2 features Loopback Detection and Cable Diagnostics to help network administrators to find and solve network problems quickly and easily. Loopback Detection is used to detect loops created by a specific port and automatically shut down the affected port. The Cable Diagnostics feature is designed for network administrators to quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
Advanced Features
The DGS-1100-05V2 is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to create a MAC whitelist for specific ports, helping administrators limit network access to authorized devices only. Storm Control monitors broadcast, multicast, or unknown unicast traffic and will start blocking or discarding packets which could flood the network when the defined threshold is exceeded. IGMP Snooping is able to reduce the loading of L3 multicast routers and save bandwidth in network throughput.
General features
Size
• Desktop
Number of Ports
• 5 10/100/1000Base-T ports
LEDs
• Power (per device)
• Link/Activity/Speed (per port)
Buttons
• Reset button
Installation
• Desktop
• Wall mounting
Standards and Functions
• IEEE 802.3 compliant
• IEEE 802.3u compliant
• IEEE 802.3ab compliant
• Supports half/full-duplex operation (half at 10/100Mbps, full at 1000 Mbps)
• Auto-negotiation
• Auto MDI/MDIX
• IEEE 802.3x Flow Control supports Full-Duplex mode
• IEEE 802.3az compliant
Performance
Switching Capacity
• 10 Gbps
Maximum Forwarding Rate
• 7.44 Mpps
MAC Address Table Size
• 2K Entries
Packet Buffer
• 128 KB
Flash Memory
• 2 MB
Software Features
VLAN
• Port-based VLAN
• 802.1Q Tagged VLAN
• Surveillance VLAN
• Voice VLAN
• Management VLAN
• VLAN Group
  - Supports 32 static VLAN groups
  - Max. 4094 VIDs
• Asymmetric VLAN
L2 Features
• Flow Control
  - 802.3x Flow Control
  - HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes
• IGMP Snooping
  - IGMP v1/v2/v3 awareness Snooping
  - Supports 128 Groups
• Static Trunk
  - 1 group, max. 4 ports per group
• Loopback Detection
• Cable Diagnostics
• Port Mirroring
  - One-to-One
  - Many-to-One
• Statistics
  - Tx Ok
  - Tx Error
  - Rx Ok
  - Rx Error
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
Quality of Service (QoS)
• 802.1p Quality of Service
• 4 queues per port
• Queue Handling
  - Strict
  - Weighted Round Robin (WRR)
• Bandwidth Control
  - Port-based (Ingress/Egress, min. granularity 8 Kb/s)
• DSCP
Security
• Static MAC Address
  - Up to 32 entries
• Traffic Segmentation
• Broadcast/Multicast/Unknown Unicast Storm Control
• Port Security
Management
• Web-based GUI (Supports IPv4)
• D-Link Network Assistant (DNA)
• SNMP v1/v2c
D-Link Green
• Power Saving by
  - Link Status
• Compliant with IEEE 802.3az Energy Efficient Ethernet
RFC Standard List
• RFC768 UDP
• RFC791 IP
• RFC792 ICMP
• RFC793 TCP
• RFC826 ARP
• RFC2236, IGMP Snooping
• RFC1213 MIBII
Power Consumption
Standby Mode
• 1.39 W
Maximum
• 3.42 W
Power Input
• 5 V/1 A Power Adapter
Heat Dissipation
• 11.67 BTU/hr
MTBF
• 1,562,055 hours
Acoustics
• 0 dB
Weight
• 0.23 kg
Dimensions
• 100.5 x 82 x 28 mm
Ventilation
• Fanless
Surge Protection
• Built-in 1 kV surge protection on copper ports
Operating Temperature
• 0 to 40 °C
Storage Temperature
• -40 to 70 °C
Operating Humidity
• 0% to 90% non-condensing
Storage Humidity
• 0% to 95% non-condensing
EMI
• FCC Class B, CE Class B, VCCI Class B, BSMI
Safety
• cUL, CE LVD, CB, BSMI
Certificates
Order info
DGS-1100-05V2   EasySmart managed switch with 5 10/100/1000Base-T ports
Pictures
DGS-1100-05V2/A1
Front view
View from the right
Back view
Downloads
Support Resources
