Description
The DPR-1260 Wireless 108G multifunction print server is a versatile multi-port print server ideal for office, school and business use. Providing 4 USB ports for 4 USB printer connections, this device give users the option of adding multiple printers, multifunction printers, or scanners to the network. With simple configuration and high wireless network speed, the DPR-1260 makes it easy to share multiple devices over the network and reduces the time required to send print jobs to the print server.
Tested with a wide range of different printer models, the DPR-1260 offers a high level of compatibility. Printing a file on a network printer is transparent, and users can easily control the scanning of documents, photos directly from their computers. The multifunction printer's scanning function can be controlled over a wireless network*. Users can share data through the memory card on the multifunction printer's slot, and print it through the same printer wirelessly. The DPR-1260 is compatible with a wide range of USB multifunction printers and scanners and is backward compatible with USB 1.1/1.0 printers.
High-Speed Wireless Connection and Expandability. The DPR-1260 offers wireless speed of up to 108Mbps Turbo mode from any computer equipped with 2.4GHz frequency band wireless interface, and an Ethernet port that can also serve as a wireless bridge. This provides wireless connectivity for any Ethernet-enabled device, such as a computer, Digital Video Recorder (DVR), or Network-Attached Storage (NAS) to the network printers.
Simultaneous Operation of Connected Printers. With 4 multifunction printer connections from a single device, the DPR-1260 is the perfect choice for environments where space or price is a concern. Equipped with a powerful CPU, large buffer size, high-speed USB ports and high-speed network data transfer, the DPR-1260 makes network operation fast. All shared devices attached to the DPR-1260 can print and scan at the same time, giving this multi-port print server a similar performance as 4 separate single-port print servers.
Network Security and Multiple O.S. Support. The DPR-1260 provides the necessary security for wireless users, using the user-selectable 64/128-bit industry-standard WEP (Wired Equivalent Privacy) data encryption and Wi-Fi Protected Access (WPA-PSK, WPA-EAP). It supports many network OS, including Windows and Linux, giving users the flexibility to install the print server regardless of the network environment.
*Not all printers are supported. Some printers may only support printing function. Host-based printers are not supported.
