DVG-6004SEOL EOS
Description
The D-Link DVG-6004S VoIP trunk gateway connects an IP network to POTS (plain old telephone service) analog lines to send IP voice and data to the conventional phone sets and fax machines. Designed as a cost-effective VoIP solution for a small to medium-sized business and the branch office, these devices provide 4 FXO (Foreign eXchange Office) ports for 4 phone line connections. IP network connection can be through any of the 2 LAN ports or the WAN port (all 10/100/1000Base-T Ethernet interfaces).
For Office Use
In a remote IP phone to local analog phone line application, a branch office can take in IP voice calls from a head office, then route them to local destinations equipped with only analog phones. The long distance calls are sent through the Internet without any phone charge, and the remote office pays only for the local analog phone time. The gateways connect analog callers to the IP network without involving operators or incurring toll charges from telephone companies.
The DVG-6004S VoIP gateway can be deployed to interface VoIP infrastructure with a Public Switched Telephone Network (PSTN)
They allow analog phone callers to place calls through the long-distance Internet trunk line. The gateways accept dial tone and ring current from the connected equipment, and facilitate the use of conventional phone sets and fax machines on a VoIP network.
Guaranteed Voice Quality
The DVG-6004S gateway delivers clear sound, voice and reliable fax calling through implementation of internationally recognized standards for voice and data networking. It incorporates Quality of Service (QoS) functions to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone.
Convenient Call Features
The DVG-6004S gateway supports extensive call features, allowing the service providers to offer these functions to their subscribers. Provided that the telephone sets at the end-users side support these functions, callers can take advantage of these convenient features. Configuration of individual phone connection is easy, using the multi-language Interactive Voice Response (IVR) or the web-based user's interface.
Shared Broadband Internet Connection/Integrated 2-Port Switch
The gateway provides a convenient router function to permit office users to share the Internet broadband line. With 2 integrated Ethernet ports, office computers can readily connect to these gateways and use their built-in NAT/DHCP server functions for automatic logon to the Internet.
General features
Interfaces
• WAN RJ-45 10/100/1000Base-T ports
• 2 LAN RJ-45 10/100/1000Base-T ports
• 4 RJ-11 FXO ports
Diagnostic LEDs
• Power
• Alarm
• Register
• Provisioning
• WAN
• LAN 1~2
• Line 1~4
Buttons
• Reset button
• Power on/off button
Voice Features
• Codecs: G.722, G.711 a/Ој-law, G.729, G.726, G.723.1, GSM 6.10 Full Rate
• DTMF Detection and Generation
• Silence Suppression & Detection
• CNG (Comfort Noise Generation)
• VAD (Voice Activity Detection)
• G.165/G.168 Echo Cancellation
• Adaptive (Dynamic) Jitter Buffer
• Call progress tone detection (FXO) and generation (FXS)
• Programmable Gain Control
• Built-in Local Mixer
• ITU-T V.152 Voice-band Data over IP Networks
SIP Call Features
• Peer to Peer Call
• Call Hold / Retrieve
• Call Waiting
• Call Pick Up
• Call Park / Retrieve (SIP Server Required)
• Call Forward - unconditional, busy, no answer
• Call Transfer - attended, unattended
• Do Not Disturb
• Speed Dialing
• Repeat Dialing
• Three-way Calling
• MWI (RFC-3842)
• Hot Line and Warm Line
Telephony Specifications
• In-Band DTMF, Out-of-Band DTMF, DTMF Relay (RFC2833 or SIP INFO)
• DTMF / PULSE Dial
• Caller ID Generation (FXS) and Detection (FXO): DTMF, FSK-Bellcore Type 1 and 2, FSK-ETSI Type 1 and 2, FSK-NTT
• FSK: РёРјСЏ звонящего, номер, дата Рё время, VMWI
• FXS metering pulse: Polarity Reversal, 12 kHz/16 kHz calling tone
• Polarity Reversal Detection (FXO) and Generation (FXS)
• T.30 FAX Bypass, T.38 Real Time FAX Relay
• Recordable Greeting Message (FXO)
• FAX and Modem over IP (up to 14,400bps)
• ROH Tone (Receiver Off-Hook Tone @ 480 Hz)
• Loop Current Suppression
IP Network Specifications
• WAN: Static IP, PPPoE, DHCP, PPTP
• Network protocols: IP, TCP, UDP, TFTP, FTP, RTP, RTCP, ARP, RARP, ICMP, NTP, SNTP, HTTP, HTTPS, DNS, DNS SRV, Telnet, DHCP Server, DHCP Client, STUN Client, UPnP, IGMP, IGMP snooping, IGMP proxy, RTSP ALG
• NAT functions
- Support up to 255 Clients
- Port Forwarding (Virtual Servers)
- DMZ
- Port Triggering
- IPv4, IPv6
• QoS support
- WAN: Diffserv, IP Precedence Priority Queue
- Rate Control
- 802.1Q (VLAN Tagging), 802.1p (Priority Tag)
- LAN: Rate Limit
• DDNS support
• Dyndns.org (Dynamic and Custom)
SIP Account Management
• By port registration
• By device registration (share account)
• Mixed mode (Hunt number for inbound, by port number for outbound)
• Invite with Challenge
• Register by SIP Server IP Address or Domain Name
• Support RFC3986 SIP URI format
SIP Method Support
• ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PING, PRACK, PUBLISH, REFER, REGISTER, SUBSCRIBE, UPDATE
SIP Call Management
• Outbound Proxy support
• Register up to 3 SIP servers
• SIP Registration Failover
• Group Hunting
• Privacy mechanism/Private extensions to SIP
• Session Timers (Update/Re-invite)
• DNS SRV support
• Call Types: Voice / Modem / FAX
• Call Routing by Prefix Number
• User Programmable Dial Plan
• Toll-Free support (FXO)
• Automatic Calling Number Manipulation (VoIP & FXO)
• CDR Client
• Manual Peer Table (for P2P calls)
• E.164 Numbering, ENUM support
Network Security Specifications
• PPTP client
• DIGEST Authentication
• MD5 Encryption
• DoS Protection
Management
• Web based configuration
• Auto-provisioning (HTTP/HTTPS/TFTP)
• Telnet
• IVR
• FTP/TFTP/HTTP software upgrade
• Configuration Backup and Restore
• Rest to Default button
• TR-069/104 (optional)
• SNMP v1/v2c/v3dvg
Physical Parameters
Power Input
• Power adapter: DC 12V / 2 A
Operating temperature
• 0В°C ~ +45В°C
Storage temperature
• -25В°C ~ +75В°C
Operating humidity
• Up to 90% (non-condensing)
Weight
• 450 g
Dimensions
• 226 x 155 x 80 mm
Certificates
Order info
DVG-6004S VoIP Gateway with 4 FXO Ports, WAN 10/100/1000Base-T Port and 2 LAN 10/100/1000Base-T Ports
