Quick find
Product features:
Unified N Access Point
EOL EOS
General features:
Power
• Power Adapter: 5V/2.5A
• Power over Ethernet: 48V DC +/-10%
Enclosure Type
• PC or plenum-rated chassis
Enclosure Size
• 203 x 203 x 48mm
Weight
• Standard chassis: 550g
• Plenum-rated chassis: 635g
Operation Temperature
• 0 to 40°C
Operation Humidity
• 10% to 90% non-condensing
Safety
• cUL, LVD (EN60950-1), UL2043 (for plenum-rated sku only)
Compliance
• EMI/EMC/RF: EN60601-1-2, FCC Class B, CE Class B, C-tick, IC, VCCI, NCC, TELEC, Wi-Fi Certified
System
• Wi-Fi Interface: 802.11b/g/n 2.4GHz 2x2 MIMO
• LAN Interface: 10/10/100 Gigabit Ethernet
• Antenna: 2x2 MIMO embedded antenna with 4 internal antennas
• Antenna Gain: 4.7 dBi
• Power Method: IEEE 802.3af Power Over Ethernet or external power adapter
Wireless Frequency
• 802.11b/g/n: 2.4GHz - 2.497GHz
Data Transfer Rate
• 802.11n:
6.5-130 Mbps (20MHz)
6.5-300 Mbps (40MHz)
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbps
• 802.11b: 11, 5.5, 2 and 1 Mbps
The Output Power of Transmitter
• 802.11b:
21 dBm at 1, 2, 5.5, 11 Mbit/s
• 802.11g:
21 dBm at 6 Mbit/s~24 Mbit/s
19 dBm at 36 Mbit/s
18 dBm at 48 Mbit/s
17 dBm at 54 Mbit/s
• 802.11n (2.4GHz/HT-20)
20 dBm at MCS0/8
20 dBm at MCS1/9
20 dBm at MCS2/10
20 dBm at MCS3/11
19 dBm at MCS4/12
18 dBm at MCS5/13
17 dBm at MCS6/14
16 dBm at MCS7/15
• 802.11n (2.4GHz/HT-40)
19 dBm at MCS0/8
19 dBm at MCS1/9
19 dBm at MCS2/10
19 dBm at MCS3/11
17 dBm at MCS4/12
16 dBm at MCS5/13
14 dBm at MCS6/14
14 dBm at MCS7/15
Receiver Sensitivity
• 802.11b:
-89 dBm at 2 Mbit/s
-84 dBm at 11 Mbit/s
• 802.11g:
-85 dBm at 6 Mbit/s
-84 dBm at 9 Mbits/s
-84 dBm at 12 Mbit/s
-82 dBm at 18 Mbit/s
-78 dBm at 24 Mbit/s
-73 dBm at 36 Mbit/s
-70 dBm at 48 Mbit/s
-68 dBm at 54 Mbit/s
- 82dBm at MCS0/8
- 79dBm at MCS1/9
- 77dBm at MCS2/10
- 74dBm at MCS3/11
- 70dBm at MCS4/12
- 66dBm at MCS5/13
- 65dBm at MCS6/14
- 64dBm at MCS7/15
-79 dBm at MCS0/8
-76 dBm at MCS1/9
-74 dBm at MCS2/10
-71 dBm at MCS3/11
-67 dBm at MCS4/12
-63 dBm at MCS5/13
-62 dBm at MCS6/14
-61 dBm at MCS7/15
Security
• SSID: 16 SSID, Station Isolation
• Wireless Security:
WEP
Dynamic WEP
WPA Personal/Enterprise
WPA2 Personal/Enterprise
• Detection & Prevention: Rogue and Valid AP Classification
• Authentication:
MAC Address Filtering
802.1x
System Management
• Web-based User Interface: HTTP/HTTPS
• Command Line: SNMP, SSH, Telnet
Products | Support  | News  | About |
