Quick find
Product features:
Full HD 180° Outdoor Wi-Fi Camera
EOL
General features:
Camera Hardware Profile
• 1/2.7” 2-Megapixel progressive CMOS sensor
• Minimum illumination:
• Color mode: 0.5 lux
• B/W mode (LEDs off): 0.1 lux
• B/W mode (LEDs on): 0 lux
• Minimum object distance 30 cm
• Lens focal length: 1.5 mm ± 3%
• Aperture: F2.0
• Angle of view (16:9):
• Horizontal: 180°
Mounting angle:
• Vertical: 0° to 90°
• Horizontal: 0° to 180°
Camera Housing
• IP65 compliant weatherproof housing*
Image Features
• Digital zoom
• Built-in microphone
• Configurable image size, quality, frame rate, and bit rate
• Wide Dynamic Range (WDR)
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable brightness
Video Compression
• Simultaneous H.264 format compression
• H.264 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1920 x 1080, 1280 x 720, 800 x 448, 640 x 360 at up to 30 fps
Audio Support
• AAC (32 kbps)
• G.711 (128 kbps)
Connectivity
• 802.11n/g/b wireless with WPA/WPA2 encryption
• 10/100BASE-TX Fast Ethernet port
• Maximum data rate of 300 Mbps (PHY rate)
• microSD/SDHC/SDXC card slot, accepts cards up to 128 GB
• Bluetooth Low Energy (BLE)
Network Protocols
• IPv6, IPv4, ARP, TCP, UDP, ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• HTTP server
• HTTPS (for configuration)
• uPnP port forwarding
• RTP/RTSP/RTCP
• Bonjour
• ONVIF
Security Features
• Administrator and user group protection
• Password authentication
• HTTP and RTSP digest encryption
System Requirements for mydlink Portal Web Management
• The latest minimum system and browser requirements for using the mydlink portal can be found on your regional mydlink website.**
Event Management
• Motion detection
• Sound level detection
• Scheduled recording
• Event notification and snapshot/video clip uploads to mobile device
Remote Management
• Configuration interface accessible via a web browser
Mobile Support
• mydlink Lite mobile app for iPhone, iPad, iPod touch and Android
Weight
• 360 grams
Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 5 V DC 1.2 A
Power Consumption
• Maximum: 5 watts ± 5%
Temperature
• Operating: -25 to 45 °C
• Storage: -20 to 70 °C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• ICES
• RCM
* IP65 standard: Effective against low-pressure water jets from all directions. It is recommended to place the device under a roof or shelter.
** Go to www.mydlink.com to see the latest supported OS and browser versions at Support > FAQ > mydlink Basic > System Requirement.
Products | Support  | News  | About |
