Quick find
Product features:
HD Wireless N Pan & Tilt Network Camera
EOL EOS
General features:
Camera Specifications
• 1/4” Megapixel Progressive CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination 0 lux with IR LED on
• Built-in Infrared-Cut Removable (ICR) Filter module
• Focal length 4.57 mm
• Aperture: F1.9
• Exposure Time: 1/50 ~ 1/15,000
• Angle of view:
• (H) 45.7°
• (V) 29.5°
• (D) 52.9°
• Built-in Microphone
Video Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable shutter speed, brightness, saturat contrast, mirror, flip
Video Compression
• H.264/MPEG4/MJPEG format simultaneous compression
• H.264/MPEG4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 (supports frame rates up to 30 fps)
• 1280 x 720
• 640 x 352
• 320 x 176
• 160 x 80
Pan/Tilt/Zoom
• Pan Range: -170° to 170°
• Tilt Range: -25° to 90°
• Digital Zoom: 4x
• Manual Pan Speed: 1-10
• Manual Tilt Speed: 1-10
• Position Presets: 10 points
Audio Compression
• ADPCM, PCM
Network Protocol Support
• IPv4
• ARP
• TCP
• UDP
• ICMP
• DHCP Client
• NTP Client (D-Link)
• DNS Client
• DDNS Client (D-Link)
• SMTP Client
• FTP Client
• HTTP Server
• PPPoE
• RTP
• RTSP
• RTCP
• 3GPP
Network Interface
• IEEE 802.11n
• 10/100 BASE-TX Fast Ethernet
External Device Interface
• MicroSD/SDHC Slot
• Audio Output
• DI/DO Port
Remote Management
• Take snapshots/video clips and save to local hard drive via web browser
• Configuration accessible via web browser Security
• Administrator and user group protected
• Password authentication
• HTTP and RTSP digest encryption
Surveillance
• Record video continuously
• Record video according to a weekly schedule
• Record video when motion is detected
• Upload snapshots/video clips via e-mail
• Upload snapshots/video clips via FTP
Mobile App Support
mydlink Lite app for iOS and Android devices
Operating System
Microsoft Windows 8/7/Vista/XP SP3
Compatible Browsers
Microsoft Internet Explorer 6 or higher, Firefox 1.5 or higher, or other Java-enabled browser
Supported Mobile Devices
• Mobile devices with a 3GPP player, such as Packet Video Player 3.0, QuickTime 6.5, or Real Player 10.5
• mydlink™ app requires a mobile device running iOS or Android
Dimensions
114 x 114 x 125 mm (4.46 x 4.46 x 4.92 inches)
Weight
540 grams (1.19 lb)
Power Input
Input: 12 V/1.25 A, 50/60 Hz
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -20 to 70 ºC (-4 to 158 ºF)
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• FCC Class B
• C-Tick
• CE LVD
Products | Support  | News  | About |
