Quick find
Product features:
L2+ Unified Wired/Wireless Gigabit Switch
EOL EOS
General features:
WLAN Management Capability
• Up to 64 APs per switch
• Up to 256 APs per cluster
• Up to 2,048 Wireless Users (1,024 Tunneled Users, 2,048 Non-Tunneled Users)
Roaming
• Fast Roaming*
• Intra-Switch/Inter-Switch Roaming
• Intra-Subnet/Inter-Subnet Roaming
• AP-AP Tunnel
Access Control & Bandwidth Management
• Up to 32 SSID per AP (16 SSID per RF Frequency Band)
• AP Load Balancing based on the number of users or utilization per AP
Managed AP
• DWL-8600AP
AP Management
• AP Auto-Discovery
• Remote AP Reboot
• AP Monitoring: List Managed AP, Rogue AP, Authentication Failed AP
• Client Monitoring: List Clients Associated with Each Managed AP
• Ad-hoc Clients Monitoring
• AP Authentication Supporting Local Database and External RADIUS Server
• Centralized RF/Security Policy Management
• Visualized AP Management Tool (Supports up to 16 jpg files)
• Unified AP Support (DWL-8600AP): Managed/Standalone mode
WLAN Security
• Wireless Intrusion Detection & Prevention System (WIDS)
• Rogue AP Mitigation
• Rogue and Valid AP Classification Based on MAC Address
• WPA Personal/Enterprise
• WPA2 Personal/Enterprise
• 64/128/152-bit WEP Data Encryption
• Wireless Station and AP Monitoring on RF Channel, MAC Address, SSID, Time
• Encryption Type Support: WEP, WPA, Dynamic WEP, TKIP, AES-CCMP, EAP-FAST, EAP-TLS, EAP-TTLS, EAPMD5,PEAP-GTC, PEAP-MS-CHAPv2, PEAP-TLS
• Captive Portal
• MAC Authentication
• Station Isolation
L2 Features
• MAC Address Table Size: 8K Entries
• IGMP Snooping: 1K Multicast Groups
• MLD Snooping
• 8021.D Spanning Tree
• 802.1w Rapid Spanning Tree
• 802.1s Multiple Spanning Tree
• 802.3ad Link Aggregation: Up to 32 groups, up to 8 ports per group
• 802.1ab LLDP
• LLDP-MED
• One-to-One Port Mirroring
• Many-to-One Port Mirroring
VLAN
• 802.1Q VLAN Tagging
• 802.1V
• VLAN Groups: Up to 3965 entries
• Subnet-based VLAN
• MAC-based VLAN
• GVRP
• Double VLAN
L3 Features
• IPv4 Static Route
• Routing Table Size: Up to 128 Static Routes
• Floating Static Route
• VRRP
• Proxy ARP
• RIPv1/v2
• Voice VLAN
• Jumbo Frame Size: Up to 9KBytes
Quality of Service
• 802.1p Priority Queues (Up to 8 Queues per Port)
• CoS Based on: Switch Port, VLAN, DSCP, TCP/UDP Port, TOS, Destination/Source MAC Address, Destination/Source IP Address
• Auto-VoIP
• Minimum Bandwidth Guarantee per Queue
• Traffic shaping per port
• Per-Flow Bandwidth Control
ACL (Access Control List)
ACL Based on: Switch Port, MAC Address, 802.1p Priority Queues, VLAN, Ethertype, DSCP, IP Address, Protocol Type, TCP/UDP Port
LAN Security
• RADIUS Authentication for Management Access
• TACACS+ Authentication for Management Access
• SSH v1, v2
• SSL v3 , TLS v1
• Port Security: 20 MAC Addresses per Port, Trap Violation Notification
• MAC filtering
• 802.1X Port-Based Access Control and Guest VLAN
• Denial of Service Protection
• Dynamic ARP Inspection (DAI)
• DHCP Snooping
• Broadcast Storm Control in Granularity of 1% of link speed
• Protected Port
• DHCP filtering
Management Methods
• Web-Based GUI
• Switch Clustering
• RADIUS Accounting
• CLI
• Telnet Server: Up to 5 Sessions
• Telnet Client
• TFTP Client
• SNMP v1, v2c, v3
• sFlow
• Multiple Configuration Files
• Dual Image Services
• RMON v1: 4 Groups (Statistics, History, Alarms, Events)
• BOOTP/DHCP Client
• DHCP Server
• DHCP Relay
• SNTP
• SYSLOG
• Dual Images
• Port Description
Device Interfaces
• 24 10/100/1000BASE-T Gigabit Ports With Integrated 802.3af PoE
• 4 Combo SFP Slots
• RS-232 Console Port
• 2 Open Slots for Optional 10-Gigabit Module
Redundant Power Supply
Connector for Optional External DPS-600 RPS
Power over Ethernet
• Standard: 802.3af
• Per Port Voltage Output: 15.4 W
• Total Voltage Output: 370 W
• Auto Disable If Port Current Over 350mA
Performance
• Switching Capacity: 88Gbps
• Maximum Forwarding Rate: 65.47Mpps
• Forwarding Mode: Store and Forward
• Packet Buffer Memory Size: 750KBytes
Flow Control
• 802.3x Standard in Full Duplex Mode
• Back Pressure in Half Duplex Mode
• Head-of-Line Blocking Prevention
Optional 10-Gigabit Uplink Modules
• DEM-410X 1-Slot 10-Gigabit XFP Modul (For Fiber Backbone Attachment)
• DEM-410CX 1-Port 10-Gigabit CX4 Module (For Switch Cascading)
Optional 10-Gigabit XFP Transceivers
• DEM-421XT XFP Transceiver (10GBASE-SR Standard, Up to 300 m Multi-Mode Fiber Distance, 3.3/5V Operating Voltage)
• DEM-422XT XFP Transceiver (10GBASE-LR Standard, Up to 10 km Single-Mode Fiber Distance, 3.3/5V Operating Voltage)
• DEM-423XT XFP Transceiver (10GBASE-ER Standard, Up to 40 km Single-Mode Fiber. Distance, 3.3/5V Operating Voltage)
Diagnostic LEDs
• Per Device: Power, Console, RPS
• Per 10/100/1000BASE-T Port: Link/Activity/Speed, PoE Mode
• Per SFP Slot: Link/Activity
• Per 10-Gigabit Slot: Link/Activity
Power
• AC Input Power: 100 to240 VAC, 50/60 Hz Internal Universal Power Supply
• Power Consumption: 525 Watts (max. with all PoE ports in operation)
MTBF
185,540 Hours
Dimensions
• 440 (W) x 389 (D) x 44 (H) mm (17.32 x 15.31x 1.73 inches)
• 19-Inch Standard Equipment Rack Mount Width, 1U Height
Weight
6kg (13.23 lbs)
Temperature
• Operating Temperature: 0° to 40° C (32° to 104° F)
• Storage Temperature: -10° to 70° C (14° to 158° F)
Humidity
• Operating Humidity: 10% to 90% non-condensing
• Storage Humidity: 5% to 90% non-condensing
EMI/EMC Certifications
FCC Class A, ICES-003, VCCI, CE, C-Tick, EN 60601-1-2
Safety Certifications
UL/cUL, CB
Products | Support  | News  | About |
