DNH-100
Nuclias Connect Controller
Description
The DNH-100 Nuclias Connect is a hardware controller with pre-loaded Nuclias Connect software. It is designed to support small-to-medium business by providing network administrators the capability to manage D-Link Nuclias Connect access points through one single device. The DNH-100 Nuclias Connect can currently manage up to one hundred APs per unit with the potential to extend to other Nuclias Connect products in future firmware updates.
DNH-100 is equipped with one Gigabit LAN port, one USB 3.0 port (offers 5V / 1A power), one MicroSD Slot and one RJ45 Console port.
DNH-100's auto-managed AP discovery and single point management allow customers to acquire an enterprise class system without the burden of executing massive and complex configurations. With a robust and comprehensive security detection system, the controller also enables managed APs to block potential attacks from unauthorized users and devices, especially for wireless environments.
General features
Interfaces
• 1 x Gigabit LAN
• 1 x USB 3.0 (offers 5V / 1A power)
• 1 x MicroSD Slot
• 1 x RJ45 Console
Standards
• IEEE 802.3u/ab
• IEEE 802.3x Flow Control
LEDs
• Power/status
• LAN
Buttons
• Reset
Network Management
• Up to 100 APs
Physical Parameters
Weight
• 529 g (without micro SD card)
Dimensions
• 190 x 100 x 31 mm
Environmental
Power
• Input: 100 to 240 V AC, 50/60 Hz
Power Consumption
• Max: 6.5 watts
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 65 °C
Humidity
• Storage: 5% to 95% non-condensing
Package Content
• Controller
• Power Cable
• Rack-mount kit
• Quick installation guide
Certifications
• CE (class B)
• FCC (class B)
• IC
• BSMI
• CE/ LVD
• UL
• RoHS
Certificates
Order info
DNH-100 Nuclias Connect Controller
