Description
SIP Telephony
The VoIP router is equipped with two FSX ports which allow connection of analog phones for calls via Internet.
USB Port
The router is equipped with a USB port for connecting a USB modem,which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
Wireless Interface
Using the DVG-N5402SP device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). The router can operate as an access point for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps). You can easily switch the router's wireless network on/off by pressing the WLAN button located on the cover of the device.
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
Security
The wireless router DVG-N5402SP includes a built-in firewall. The advanced security functions minimize threats of hacker attacks and prevent unwanted intrusions to your network.
Configuration and Management
You can configure and manage the settings of the wireless router DVG-N5402SP via the user-friendly web-based interface (the interface is available in several languages).
General features
WAN Interface
• 1 10/100/1000BASE-TX Ethernet port for cable or DSL modem or private Ethernet line
LAN Interface
• 4 10/100/1000BASE-TX Ethernet ports
WLAN Interface
• IEEE 802.11n (up to 300Mbps)
• IEEE 802.11b/g
FXS Interface
• 2 FXS ports for connecting analog phone or fax machines
USB Interface
• USB 2.0 type A port for USB modem, storage, or printer
Frequency Range
• 802.11b
- 2400 ~ 2484MHz ISM band
• 802.11g
• 802.11n
- HT20: 2400 ~ 2483.5MHz ISM band
- HT40: 2422 ~ 2452MHz ISM band
Data Rate
• 802.11b
- 11, 5.5, 2, and 1Mbps per channel, auto fallback
• 802.11g
- 54, 48, 36, 24, 18, 12, 9, and 6Mbps per channel, auto fallback
• 802.11n
- HT20: up to 150Mbps
- HT40: up to 300Mbps
Modulation Schemes
• 802.11b: CCK, DQPSK, DBPSK
• 802.11g: 64QAM, 16QAM, QPSK, BPSK, DSSS
• 802.11n: 64 QAM, 16QAM, QPSK, BPSK
Software Features
General SIP Features
• Individual account per port
• Invite with Challenge
• Register by SIP server IP address or domain name
• RFC3986 SIP URI format support
• Outbound proxy support
• Session timers (update/re-invite)
• DNS SRV Support
• Call types: voice/modem/fax
• User programmable Dial Plan
• Manual peer table (for P2P calls)
• E.164 Numbering, ENUM support
Call Features
• Direct IP-to-IP сall without SIP proxy
• Call hold / retrieve
• Call awaiting
• Forwarding (unconditional, busy, no answer)
• Do Not Disturb
• MWI (Message Waiting Indication)
• Anonymous call blocking
• CLIR
• Speed dialing
• Hotline
Voice Features
• Codecs: G.711 a/mu-law, G.729A, G.726, G.722
• DTMF detection and generation
• Comfort Noise Generation (CNG)
• Voice Activity Detection (VAD)
• Adaptive (Dynamic) Jitter Buffer
• Call progress tone generation (FXS)
• Programmable Gain Control
• In-band DTMF, out-of-band DTMF (RFC2833, SIP-INFO)
• DTMF/PULSE dial support
• Caller ID detection and generation
• T.30 FAX bypass to G.711, T.38 Real Time FAX Relay
Network Functions
• WAN connection types:
- 3G
- PPPoE
- Static IP
- Dynamic IP
- PPTP/L2TP
- PPTP/L2TP + Static IP
- PPTP/L2TP + Dynamic IP
• DHCP server and client
• DNS relay
• VPN pass-through (PPTP/L2TP)
• Dynamic DNS
• Static IP routing
• Remote management
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• Support of VLAN
• WAN ping respond
USB Modem*
• Auto connection to available type of supported network (3G/2G)
• Enabling/disabling PIN code check, changing PIN code
USB Storage
• SMB-based access
• Built-in FTP server
• Print server
• Access to storage via accounts
Wireless Connection
• Supported security settings:
- WEP
- WPA/WPA2 Personal
- WPA/WPA2 Enterprise
• MAC filter
• PIN and PBC methods of WPS
• WMM (Wi-Fi QoS)
• Advanced settings
Torrent Client
• Uploading/downloading files from/to USB storage
Firewall Functions
• IP filters
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Support of remote logging
• Ping function
• Traceroute utility
Supported USB Modems*
• GSM modems
- D-Link DWM-152
- D-Link DWM-156
- Huawei E160G
- Huawei E169G
- Huawei E171
- Huawei E220
- ZTE MF112
- ZTE MF192
- ZTE MF626
- ZTE MF627
- ZTE MF652
- ZTE MF668
- ZTE MF752
• CDMA modems
- Airplus MCD-650
- Airplus MCD-800
- AnyDATA ADU-300A
- AnyDATA ADU-500A
- AnyDATA ADU-510A
- ZTE AC5710
- ZTE AC5730
LEDs
• POWER
• WAN
• 4 LAN LEDs
• WLAN
• WPS
• USB
• 2 FXS LEDs
Power
• External power adapter DC 12V/1.25A
Buttons
• Power on/off button
• Reset to Factory Defaults button
• WPS button
• WLAN on/off button
Operating Temperature
• From 0° to 40°C
Storage Temperature
• From -20° to 70°C
Operating Humidity
• From 10% to 90% non-condensing
Storage Humidity
• From 5% to 95% non-condensing
* The manufacturer doesn't guarantee proper operation of the router with every modification of the firmware of USB modems.
Certificates
Order info
DVG-N5402SP/2S1U/C1A Wireless N300 Router with 3G Support, 2 FXS Ports, and USB Port
