DUB-E100EOL
Description
The DUB-E100 Hi-Speed USB 2.0 Fast Ethernet Adapter is a high-speed adapter that plugs into any available USB port on your computer to enable you to connect to an Ethernet network. The adapter eliminates the need to open your computer to install a network card, and it also lets you keep your notebook’s expansion slot free for other uses.
Easy to Install and Use
The DUB-E100 Hi-Speed USB 2.0 Fast Ethernet Adapter connects to your computer’s USB port and is ready to run almost as soon as it’s plugged in. There is no need to change any confguration settings on your computer as the drivers install automatically after you insert the DUB-E100 CD. For extra convenience, the adapter’s USB connector can be folded into the body, allowing it to be even more compact when not in use and being carried around.
Energy Saving
The DUB-E100 supports an energy-saving suspend and resume function to minimize power consumption, which is especially useful for notebook users as it helps conserve battery life, allowing them to use their notebooks for a longer period. Power is provided directly by the USB bus, eliminating the need for an external AC power adapter.
General features
Standards
• USB Specification Version 2.0
• USB Specification Version 1.1
• USB Specification Version 1.0
• OHCI (Open Host Controller Interface)
• EHCI (Enhanced Host Controller Interface)
• IEEE 802.3 Ethernet
• IEEE 802.3u 100BASE-T, TX, and T4 compatible
• Supports suspended mode and remote wakeup
• Supports full and half duplex in Fast Ethernet device interfaces
Device Interfaces
• USB Type A connector
• RJ-45 (10/100 Mbps Dual-Speed)
Minimum System Requirements
• Operating System: Microsoft Windows 8/7/Vista/XP SP3, Mac OS 10.5 to 10.10, and Linux Configuration/Management
• Advanced Power Management reduces power usage during idle or light traffic periods
Physical
LED
• Power/LinkLAN
• Tx/Rx Traffic
Power
• Bus Powered 0.5 A, 5 V DC
Power Consumption
• 150 mA, 3.3 V DC
Dimensions (L x W x H)
• 73 x 21.3 x 20 mm (2.87 x 0.84 x 0.79 inches)
Weight
• 22 g (0.05 pounds)
Operating Temperature
• 0 ˚C to 40 ˚C (32 ˚F to 104 ˚F)
Storage Temperature
• -10 ˚C to 70 ˚C (14 ˚F to 158 ˚F)
Operating Humidity
• 5% to 95%, non-condensing
Storage Humidity
• 0% to 95%, non-condensing
Certifications
• CE
• C-Tick
• FCC Class B
Certificates
Order info
DUB-E100 USB 2.0 Ethernet Adapter
