DCS-3511
HD PoE Network Camera / HD Wireless N Network Camera
Description
The D-Link DCS-3511/DCS-3530 are fully featured entry-level HD network cameras, equipped with 1 Megapixel Progressive Scan CMOS sensor and 2.8 mm to 12 mm DC iris vari-focal lens. The cameras can capture HD video at resolutions of up to 1280 x 800 with frame rates up to 30 fps. Snapshots and video can be saved to a network drive, or to onboard storage with the built-in microSD Card slot.
High Definition Surveillance
The DCS-3511/DCS-3530 is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 720p HD. This gives you sharp, high-resolution snapshots and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera’s video so you can survey a large area easily. A Power over Ethernet (PoE) port* allows you to connect the DCS-3511 to your network and power it through a single cable, simplifying deployment and doing away with the need for a nearby power outlet.
High Speed Access To Multiple Video Streams
The DCS-3511/DCS-3530 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. Additionally, the DCS-3511/DCS-3530 supports multicast H.264 and MPEG-4 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network. The DCS-3530 also has wireless connectivity which means there is no need for additional cabling, allowing for flexible placement and hassle-free installation.
A Complete, Expandable Surveillance Solution
The DCS-3511/DCS-3530 is a self-sufficient surveillance solution, capable of recording snapshots and video to a microSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
General features
Camera Hardware Profile
• 1/4" 1 Megapixel CMOS sensor
• 2.8mm to 12mm DC iris vari-focal lens
• Aperture F1.4
• Built-in IR Cut filter Removable (ICR)
• Shutter speed 1/5 to 1/10,000 sec.
• Minimum Illumination: 0.1Lux (Color); 0.05Lux (B/W)
• Angle of view
77.5-22.7° (H)
53.3-14.5° (V)
82.5-27° (D)
• Minimum Object Distance: 0.2 m
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• 3 configurable motion detection windows
• 5 configurable privacy mask zones
• Configurable brightness, saturation, contrast, and sharpness
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 800, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176 up to 30 fps recording**
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240 up to 30 fps recording**
Audio Support
• MPEG-4 AAC audio encoding, bit rate: 16 kbps to 128 kbps
• G.711 audio encoding, bit rate: 8 kbps to 64 kbps
External Device Interfaces
• 10/100 BASE-TX Fast Ethernet port
• Supports 802.3af PoE*
• DI/DO socket for connection to external devices
• RS-485 for external PTZ connection
• microSD/SDHC card slot
• External Audio input/output
Network Protocols
• IPv4
• IPv6
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP/HTTPS
• 802.1x
• Samba client
• PPPoE
• UPnP port forwarding
• RTP/RTSP/RTCP
• IP filtering
• QoS
• CoS
• Multicast
• IGMP
• ONVIF compliant
• SNMP v1/v2/v3
Security
• Administrator and user group protection
• Password authentication
• HTTPS encryption for web access
• HTTP and RTSP authentication
System Requirements for Web Interface
•Browser: Internet Explorer, Firefox, Chrome
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive via web browser
• Configuration interface accessible via web browser
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 8/7/Vista/XP
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
• Supports all management functions in web interface
Certificates
Order info
DCS-3511 HD PoE Network Camera / HD Wireless N Network Camera
