DGS-1100-08PV2
8-Port 10/100/1000 Mbps (PoE) Smart Managed Switch
Description
The DGS-1100-08PV2 is a switch designed to meet the requirements of small, medium, and enterprise businesses. Support for multiple PoE standards make the DGS-1100-08PV2 ideal for IP surveillance deployments. Advanced management features, a range of diagnostic and troubleshooting tools, and energy efficient technologies provide a flexible solution to meet your networking requirements.
D-Link Green/Power Saving Performance
Compliant with IEEE 802.3az Energy Efficient Ethernet (EEE), the DGS-1100-08PV2 consumes less energy by cutting down on power consumption when port utilization is low. By deploying compatible devices, users can cut operating costs and even cut down on additional cooling equipment, helping small and medium-sized businesses stay within their budgets. The DGS-1100-08PV2 also features D-Link Green technology that helps save energy automatically.
Easy to Deploy
The DGS-1100-08PV2 supports an intuitive web-based management interface. The web-based interface provides a user-friendly way for network administrators to manage the switch down to the port level. The interface can be accessed from a web browser, allowing the switches to be controlled from any PC that is connected to the network.
Surveillance VLAN and Bandwidth Control
The DGS-1100-08PV2 supports surveillance VLAN for IP surveillance deployments. This gives video traffic a dedicated VLAN and higher priority through the switch, separating surveillance traffic from the rest of the network. This ensures security and guarantees the quality of the video traffic, sparing businesses the added cost of dedicated surveillance hardware. Bandwidth Control can reserve bandwidth on a per-port basis for important functions that require larger bandwidth or have higher priority.
Advanced Features
The DGS-1100-08PV2 is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to create a MAC whitelist for specific ports, helping administrators limit network access to authorized devices only. Storm Control monitors broadcast, multicast, or unknown unicast traffic and will start blocking or discarding packets which could flood the network when the defined threshold is exceeded. IGMP Snooping is able to reduce the load of L3 multicast routers and save bandwidth in network throughput.
Easy Troubleshooting
The DGS-1100-08PV2 features Loopback Detection and Cable Diagnostics to help network administrators find and solve network problems quickly and easily. Loopback Detection is used to detect loops created by a specific port and automatically shuts down the affected port. Cable Diagnostics helps network administrators quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
PoE Support
The DGS-1100-08PV2 provides Power over Ethernet (PoE) support, reducing deployment time for IP cameras, VoIP phones, and access points. Dedicated power adapters are no longer required, as the DGS-1100-08PV2 comply with IEEE 802.3af and 802.3at PoE standards and provide up to 30 watts per port.
General features
Interfaces
• 8 10/100/1000BASE-T (PoE) ports
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3ab 1000BASE-T
• IEEE 802.3af
• IEEE 802.3at
• Auto-negotiation
• Supports half/full-duplex operation (half at 10/100 Mbps, full at 1000 Mbps)
• Auto MDI/MDIX
• IEEE 802.3x Flow Control supports full-duplex mode
LEDs
• Power
• Link/Activity/Speed (per port)
• PoE OK/PoE Fail (per port)
• PoE Max
Performance
Switching Capacity
16 Gbps
Transmission Method
• Store-and-forward
Max. Packet Forwarding Rate
• 11.9Mpps
MAC Address Table
• 4K entries per device
Packet Buffer Size
• 1.5 Mbits
Flash Memory
• 2 Mbytes
Jumbo Frame
• 9,216 Bytes
PoE
PoE Standard
• 802.3af
• 802.3at
PoE Capable Ports
• Port 1 to 8
• Max. 30 W per port
PoE Power Budget
64W
Physical/Environmental
Power Input
• AC:100 ~ 240 V (54V/1.574A power adapter)
Power Consumption
• Standby Mode: 2.0 W
• Maximum:
  77.9 W (PoE on)
  4.6 W (PoE off)
Heat Dissipation
• 265.85 BTU/hr
MTBF
• 786,841 hours
Ventilation System
• Fanless
Temperature
• Operating: 0 ~ 40  °C
• Storage: - 40 ~ 70 °C
Humidity
• Operating: 0 to 90% non-condensing
• Storage: 0 to 95% non-condensing
Dimensions
• 171 x 97.8 x 28.6 mm
Weight
• 0.433 kg
Certificates
Order info
DGS-1100-08PV2  8-Port 10/100/1000 Mbps (PoE) Smart Managed Switch
