Description
ROUND-THE-CLOCK SURVEILLANCE
D-Link DCS-3411 is a versatile day and night network camera, ideal for small-to-medium business applications and remote monitoring over the internet. The camera employs a superior CMOS sensor with low lux sensitivity to deliver a truly superior image quality under varied lighting conditions. The DCS-3411 is equipped with 2 digital input ports for sensors or alarms, 1 digital output port for an alarm, 1 power output port for an LED illuminator and a BNC connector which provides both analog and digital video transmission interfaces. 802.3af compliant Power over Ethernet (PoE) eases the installation process by providing both data and power connections through a single cable. An rS-485 port is also included for external pan/tilt devices. In addition, the 12v interface provides power for an optional LED illuminator. A built-in infrared Cut removable (ICR) filter in the DCS-3411 allows the camera to capture images in both regular and low light conditions. Additional accessories such as an auto iris lens, an IR LED lens, a night vision illuminator, and an outdoor enclosure can be added to the DCS-3411.
VIEW LIVE VIDEO FROM A 3G MOBILE PHONE
A live feed from the camera can be accessed on a 3G mobile network using a compatible mobile phone or PDA with a 3G video player. Users have a flexible and convenient way to remotely monitor a home or office in real time anywhere within their 3GPP service area.
FLEXIBLE CONNECTIVITY
Power over Ethernet (PoE) connectivity allows for discreet installation in virtually any indoor location. For effective surveillance around any space, this camera’s built-in 802.3af compliant PoE module eases the installation process by reducing the need to lay additional cabling. In addition, the 10/100bASE-tX Ethernet port connects seamlessly to local network or to the internet via a gateway router. The camera can be accessed and viewed as a device on the network.
REMOVABLE IR CUT FILTER FOR CONTINUOUS MONITORING
The IR Cut Filter can be manually applied via web GUI, or set to automatically adjust based on lighting conditions. This feature enables the camera to capture crisp color images during the daytime, and grayscale images in low-light.
TRIPLE CODEC & MULTIPLE PROFILES
To maximize bandwidth efficiency and improve image quality, DCS-3411 provides real-time video compression in MJPEG, MPEG-4 and h.264 formats. Furthermore, the DCS-3411 supports 4 separate profiles simultaneously and is capable of recording in MJPEG, MPEG-4 and h.264 compression with D1/CIF/QCIF resolution for a smooth performance. this kind of versatility enables a wide variety of security applications such as keeping an eye on your home during lunch through a 3G enabled PDA, managing an organized directory of recorded video files on a network attached storage (NAS) device/SD card, or fine-tuning a security system in real-time over the local network.
General features
CAMERA SPECIFICATIONS
• Built-in 1/4” CMOS sensor
• Built-in IR-cut removable Filter
• Minimum illumination: 0.5 lux @ F1.8 (typical); 0
• Meter range with optical IR lens)
• CS mount lens: 6mm, F1.8
• Resolution: 640 x 480
• Electronic Shutter:
NTSC: 1/60 ~ 1/100,000 sec.
PAL: 1/50 ~ 1/110,000 sec.
• Lens mount support: Auto-iris or IR lens (10meter range)
• Field of view: 51° diagonal, 31°vertical, 41° horizontal
LED INDICATORS
• Link & Activity
• Power
RESET BUTTON
Reset to factory default settings
EXTERNAL DEVICE INTERFACE
• 2 inputs:
Photo relay
Active high 12v, +/-3v, dropout: 0 VDC
• 1 Output:
Photo relay
Close circuit current: AC 70mA or DC 100mA; 400hm
Open circuit voltage: 240vAC or 350vdC
Power output: 12v DC 200mA
• RS-485 connector for external Pt devices
MEMORY
SDRAM: 64 MBytes
VIDEO FEATURES
• Adjustable image size, quality and bit rate time stamp and text overlays
• Motion adaptive de-interlacing
VIDEO RESOLUTION
• NTSC support:
Up to 30 fps at 176x120
Up to 30 fps at 352x240
Up to 30 fps at 704x480
• PAL support:
Up to 25 fps at 176x144
Up to 25 fps at 352x288
Up to 25 fps at 704x576
VIDEO ALGORITHM SUPPORT
• JPEG for still images
• MJPEG/ MPEG4/h.264 multi-profile compression
• Supports up to 4 video profiles simultaneously
• Supports 3GPP mobile surveillance
DIGITAL ZOOM
16X
MICROPHONE
• Omni-directional
• Frequency: 20 to 20,000 Hz
• S/n ratio: over 58dB
AUDIO
• Sampling rate:
GSM-AMR: 12.2kbps
PCM: 8kbps
• Full duplex audio communication
NETWORK CONNECTIVITY
• 10/100Mbps Fast Ethernet Auto-negotiation
• Power over Ethernet
NETWORK INTERFACE
• IEEE 802.3/802.3u 10/100bASE-tX Ethernet port
• Supports full-duplex operations
• Supports 802.3x Flow Control in full-duplex mode
NETWORK PROTOCOL SUPPORT
IPV4, ARP, TCP/IP, UDP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPNP, DDNS, PPPoE, Samba Client, 3GPP
REMOTE MANAGEMENT
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive via web browser or to NAS or SD card
SECURITY
• Administrator and user group protected
• Password authentication
D-VIEWCAM SOFTWARE FUNCTIONS
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Management functions are provided in the web interface
• Scheduled, motion triggered, or manual recording options
SYSTEM REQUIREMENTS
• Operating System: Microsoft windows 2000, XP or vista
• Browser: internet Explorer, Firefox, Mozilla or Opera
• 3GPP Mobile Phone
Certificates
Order info
DCS-3411 Day & night PoE network camera with 3G mobile video support
