DES-1010PNew
10-Port Fast Ethernet Unmanaged PoE Switch
Description
Deploy a dedicated local network to streamline your retail counters or business stations. The D-Link® DES-1010P 10-Port compact switch offers instant, plug-and-play expansion to bridge IP cameras, access points, and routers with zero setup. This economical solution ensures reliable connectivity while maximizing energy efficiency.
Smart and Effortless Connectivity
This 10-Port Fast Ethernet Unmanaged Switch features auto-sensing 10/100 Mbps ports that automatically optimize connection speeds for IP cameras, VoIP phones, and PCs. Standard Ethernet cable support and clear front-panel LED indicators make network expansion and monitoring fast and simple.
Flexible PoE Power Budget
The switch supports both IEEE 802.3at and IEEE 802.3af PoE protocols. With a total PoE budget of 90 watts, it allows users to attach IEEE 802.3af/at-compliant devices without requiring additional power sources. PoE is especially suitable for devices far from power outlets or when users want to minimize cable clutter, as power is supplied directly via Ethernet cables.
Green Technology
Designed with eco-friendly technology, the DES-1010P incorporates IEEE 802.3az EEE and link status detection. It automatically reduces power consumption during low network traffic and shuts down inactive ports when devices are turned off, seamlessly lowering energy costs without impacting performance.
General features
Features
Interfaces
• 8 x 10/100Base-TX PoE ports
• 2 x 10/100/1000Base-T ports
LEDs
• Power (per unit)
• Link/Activity (per port)
• PoE (per port)
DIP
• Port Isolation
• Extend Mode
• PD Alive
Case
• Metal
Installation
• Desktop
Standards
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3af/at
Advanced Features
• Auto MDI/MDIX crossover for all ports
Functionality
Switching Fabric
• 5.6 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 2K entries
MAC Address Learning
• Automatic update
Max. Packet Forwarding Rate
• 4.17 Mpps
Packet Buffer Size
• 512 KB
Jumbo frame
• 9 KB
PoE
PoE-Enabled Ports
• Ports 1 to 8
Maximum PoE Budget
• 90 W (30 W per PoE port)
Physical/Environmental
Power
• 48 V / 2 A
Max Power Consumption
• PoE On: 96 W
• PoE Off: 7.12 W
Standby Power Consumption
• 2 W
Heat Dissipation
• 328 BTU/hr
MTBF
• 100,000 hours
Acoustic
• 0 dB
ESD protection
• Supports up to 6 kV on copper ports (compliant with IEC 61000-4-5)
Ventilation System
• Fanless
Temperature
• Operating: 0 ~ 40 °C
• Storage: -40 ~ 70 °C
Humidity
• Operating: 10 to 90% non-condensing
• Storage: 5 to 90% non-condensing
Dimensions
• 184 x 94 x 27 mm
Weight
• 1.1 kg
Certifications
• RoHS
EMI/EMS
• CE (Class A)
• FCC (Class A)
Safety
• LVD
Certificates
Order info
DES-1010P 10-Port Fast Ethernet Unmanaged PoE Switch
