Description
The DSS-100E-9P is a member of D-Link premier PoE Surveillance Switch family. These surveillance switches are the safest, most reliable and all around best solutions for your surveillance deployments. Supporting long range power delivery and upholding strict surge protection standards, the DSS-100E-9P 9-Port 10/100 PoE Unmanaged Surveillance Switch provides the ideal solution for your surveillance and security systems.
Auto detection for long range deployment
The DSS-100E-9P makes life easy; no DIP switch configuration and no restart required. The DSS-100E-9P can simply detect long range requirements, then automatically activate extended mode without any manual configuration. It can provide power delivery up to 250m without the need for PoE extenders. This feature not only streamlines PoE set up, but also cuts down on your deployment installation expenses.
Reliable Protection on Every Port
The DSS-100E-9P 9-Port 10/100 PoE Unmanaged Surveillance Switch supports 6kV surge protection to defend your surveillance network against lightening and other incidents resulting in overvoltage. This prevents PoE devices from damage and ensure no interuptions or blackouts in your surveillance systems.
Gigabit Uplink Connection
The DSS-100E-9P is equipped with one Gigabit uplink port, giving you the power to expand and secure your nework. This will provide sufficient bandwidth and ensure smooth transmission performance when connecting to an NVR or another switch.
General features
Interface
• 8 x 10/100 Mbps Fast Ethernet ports
• 1 x 10/100/1000 Mbps Ethernet port
Port Standards & Functions
• IEEE 802.3 compliant
• IEEE 802.3u compliant
• IEEE 802.3ab compliant
• IEEE 802.3af/802.3at compliant
• IEEE 802.3x Flow Control
• Auto MDI/MDIX adjustment for all ports
Performance
Switching Capacity
• 3.6 Gbps
Switching method
• Store and forward
MAC Address Table Size
• 2K Entries
Maximum 64-byte Max.packet Forwarding Rate
• 2.6784 Mbps
DRAM Size
• 128 MB
Packet Buffer
• 128 KB
Flash Memory
• 1 KB
LEDs
• Power (per device)
• Link/Activity/Speed (per port)
• PoE OK/PoE Fail (per PoE port)
PoE Standard
• IEEE 802.3af
• IEEE 802.3at
PoE Capable Ports
• Ports 1 to 8
PoE Power Budget
• 92 W (30 W max. per PoE port)
Physical/Environmental
MTBF (Hours)
• 52 308 hours
Acoustic
• 0 dB
Heat Dissipation
• Max: 486.7 BTU/hr
• Standby: 22.67 BTU/hr
Power Input
• AC Input: 100 to 240 V AC, 50/60 Hz
Maximum Power Consumption
• 102 W
Standby Power Consumption
• 10 W
Surge Protection
• Up to 6 kV on all Ethernet ports
Dimensions (W x D x H)
• 177 x 104 x 26 mm
Weight
• 0.41 kg
Ventilation
• Fanless
Operating Temperature
• 0 to 40 В°C
Storage Temperature
• -10 to 70 В°C
Operating Humidity
• 0% to 95% non-condensing
Storage Humidity
Certificates
• CE, RoHS
Safety
• LVD
Certificates
Order info
DSS-100E-9P/A1 9-Port 10/100 PoE Unmanaged Surveillance Switch
