DPS-510EOL EOS
Description
The DPS-510 is the backup Redundant Power Supply for the DES-3010PA. When the DES-3010PA is equipped with the DPS-510, both power supplies are switched on and share the current load. In case the power supply of the DES-3010PA should fail, the DPS-510 will instantaneously take 100% of the load without any loss. The DPS-510 provides up to 130 Watts of redundant power to help insure that even PoE powered devices such as phones, APs, and cameras remain alive and active in the event the internal power supply fails. In addition, the DPS-510 also supports a fan-failure signal to indicate when a fan is about to fail based on detected reduced fan RPM. The DPS-510 is rack mountable and can be mounted in an EIA standard-size 19-inch rack. If rack mounting is not required, the DPS-510 can also be easily placed on a desktop or wiring closet shelf. The DPS-510 includes everything you need to get started right out of the box including: AC Power cord, RPS cable for connecting to the DES-3010PA, Rack mounting brackets for rack installations and rubber feet for desktop or shelf mounting.
General features
LEDs
Power, Fan Failure
Protection
Over voltage protection; short circuit protection
Certificates
Order info
DPS-510 130 Watt Redundant Power Supply
