![](/up/prod/600/DWA-192_B1.jpg)
DWA-192
Wireless AC1900 Dual Band USB 3.0 Adapter
Aprašymas
Blazing-fast Wireless AC & USB 3.0
The DWA-192 Wireless AC1900 Dual Band USB 3.0 Adapter lets you experience faster wireless speeds than ever before by delivering powerful Wireless AC* technology to your desktop or notebook computer. Simply plug the adapter into an available USB port and connect to a wireless network to access a secure, high-speed Internet connection over the 2.4 GHz (600 Mbps) and 5 GHz (up to 1300 Mbps) bands**, for faster streaming, gaming, and VoIP calls. USB 3.0 support provides super-fast throughput for your desktop or notebook computer, ensuring that you are getting the most out of your Wireless AC connection.
Interference-Free Bandwidth
The DWA-192 adapter delivers dual-band technology to your home network, providing interference-free 5 GHz bandwidth. Check your email and surf the Internet on the 2.4 GHz band; play online games, make calls over the Internet, and stream HD movies to multiple devices using the cleaner, interference-free 5 GHz band. Whatever you like to do online, dual-band has you covered.
Easy WPS Push-Button Setup
Use Wireless Protected Setup (WPS) to quickly and easily establish a highly secure home network that will have you browsing, streaming, and watching in minutes. The latest encryption technology ensures that information transmitted on your network remains protected, while preventing unauthorized access. It’s as easy as push and connect!
Compatible With All Your Wireless Products
While the DWA-192 adapter delivers cutting-edge 802.11ac speed to your home network, it’s also backward compatible with all of your current wireless products.
* The DWA-192 supports the last version of 802.11ac standard – 802.11ac Wave 2.
** Maximum wireless signal rate derived from IEEE 802.11ac and IEEE 802.11n specifications. D-Link makes no warranties as to forward compatibility with future standards or compatibility with 802.11ac devices from other manufacturers. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Bendros charakteristikos
Interfaces
• USB 3.0
LEDs
• Status LED
Buttons
• WPS button
Antenna
• Integrated 2 dBi antenna
Standards
• IEEE 802.11a/b/g/n/ac*
MU-MIMO Support
• Yes
Frequency Range
• 802.11b/g/n: 2.4 GHz to 2.4835 GHz
• 802.11a/n/ac: 5.15 GHz to 5.35 GHz, 5.725 GHz to 5.825 GHz**
Wireless Security
• Wi-Fi Protected Setup
• 64/128-bit WEP
• WPA/WPA2
• WPA-PSK/WPA2-PSK (TKIP/AES)
Wireless Speed***
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbps
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbps
• IEEE 802.11n: 6.5 to 450 Mbps (MCS0 to MCS23), up to 600 Mbps (QAM256)
• IEEE 802.11ac: 58.5 to 1300 Mbps (MCS0 to MCS9)
Requirements
Operating System
• Windows Vista/7/8/8.1/10, Linux, Mac OS
Interface
• USB port****
Physical Parameters
Dimensions (L x W x H)
• 94 x 37 x 16 mm
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 60 °C
Humidity
• Storage: 5% to 95% non-condensing
** Please note that operating frequency ranges vary depending on the regulations of individual countries and jurisdictions. The DWA-192 may not support the 5.25-5.35 GHz and 5.47-5.725 GHz frequency ranges in certain regions.
*** Maximum wireless signal rate derived from IEEE 802.11ac and IEEE 802.11n specifications. D-Link makes no warranties as to forward compatibility with future standards or compatibility with 802.11ac devices from other manufacturers. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
**** Using a USB 1.1 or USB 2.0 port will affect device performance. USB 3.0 port is recommended.
Sertifikatai
Informacija užsakymui
