DPN-100Projektams
GPON SFP ONT Module
Aprašymas
DPN-100 GPON ONT Module extends the GPON deployment in existing access network by transforming Uplink port from Ethernet to GPON. DPN-100 provides the standard SFP package with SGMII interface, which can easily replace the Ethernet SFP module existing in Ethernet gateway, switch, router etc.
Compliant with ITU-T G.984 and SFP MSA, DPN-100 Optical Network Terminal is equipped with OMCI stack, bi-directional optical transmitter and GPON MAC. The DPN-100 Transceiver supports up to 1.244 Gbps upstream and 2.488 Gbps downstream data rates.
Bendros charakteristikos
General
Interface
• 1 х 1000Base-X port
Transceiver Type
• SFP
Connector
• SC/APC
Unidirectional / Bidirectional
• Bidirectional
Standards
• ITU-T G.984.x (G.984.5 support)
• SFP MSA, INF-8074i
• SFF-8472
• FCC 47 CFR Part 15, Class B
• FDA 21 CFR 1040.10 & 1040.11, Class I
• IEEE 802.3
• ITU-T G.984.2 Amd1, Class B+
Maximum Cable Length
• 20 km
Data Rate
• Up to 1.244 Gbps Upstream; up to 2.488 Gbps Downstream
Cable Type
• Single-mode
Wavelength
• Tx: 1310 nm, Rx: 1490 nm
Transmit Power Range
• Max.: 5 dBm
• Min.: 0,5 dBm
Sensitivity
• -28 dBm
Saturation Optical Power
• -8 dBm
Supported Features
• Hot Swap
• 32 GEM-ports
• 8 T-CONTs
• Multicast GEM (up to 128 groups)
• FEC Support
• DBA Support
• 8 Priority Queues
• Serial Number / PLOAM Password Log in
• Dying gasp
Physical
Dimensions (L x W x H)
• 71,8 х 13,8 х 11,09 mm
Weight
• 30 g
Working Environment
Power Support
• 3.3 V
Max. Supply Current
• 750 mА
Consumption
• < 2 W
Temperature
• Operating: -30° to +60°C
• Storage: -20° to +85°C
Humidity
• Operating: 5% to 95%, non-condensed
Additional Information
Safety & EMI
• RoHS
• FCC/UL
• CE
Supply Package
• DPN-100 Module
Sertifikatai
Informacija užsakymui
DPN-100 GPON SFP ONT Module
