DIS-100G-06P
Industrial Switch with 4x10/100/1000Base-T PoE Ports and 2x1000Base-X SFP Ports
Aprašymas
The DIS-100G-06P Gigabit Industrial Unmanaged PoE Switch features a robust design, making it ideal for deployment in industrial and outdoor cabinet surveillance settings and capable of withstanding the harshest environments. In addition, the DIS-100G-06P is plug-and-play, allowing for effortless and swift deployment.
Durable, Reliable, and Efficient
The DIS-100G-06P switch is housed in a highly resistant IP40-rated metal casing to protect the switch from harsh environmental conditions. High electromagnetic susceptibility (EMS) protects the DIS-100G-06P from undesirable effects when operating in environments with strong electromagnetic interference. Meanwhile, the fanless design extends the life of the DIS-100G-06P while also enabling it to operate in a wide temperature range from -40 °C up to 75 °C. With DIN rail mounting capability, the DIS-100G-06P can fit seamlessly into your industrial equipment infrastructure. In addition, the DIS-100G-06P supports dual power input, which allows for a redundant power supply configuration to make sure the switch continues to operate in the event of a primary power supply failure.
Green Ethernet Technology
The DIS-100G-06P features green technology; IEEE 802.3az Energy-Efficient Ethernet (EEE). Energy-Efficient Ethernet reduces the power consumption of the switch when network utilization is low, effectively lowering the cost of ownership during periods of inactivity.
Bendros charakteristikos
Hardware Version
• A1
Number of Ports
• 4 10/100/1000Base-T PoE ports
• 2 1000Base-X SFP ports
Diagnostic LEDs
• Power
• Link/Act (per port)
• PoE (per PoE port)
Material
• IP40-rated metal casing
Installation
• DIN rail mountable
Port Functions
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3z 1000Base-X
Media Interface Exchange
• Auto-MDI/MDIX adjustment for all twisted pair ports
Switching Capacity
• 12 Gbps
Transmission Method
• Store-and-forward
Maximum Forwarding Rate
• 8.92 Mpps
MAC Address Table Size
• 8K entries
Packet Buffer Memory
• 4.1 MB
Jumbo Frame
• 9 KB
Flash Memory
• 16 MB
DRAM Size
• 128 MB
Advanced Features
• Power saving by link status
PoE Standards
• IEEE 802.3at
• IEEE 802.3af
PoE Ports
• Ports 1 to 4
PoE Mode
• Ports 1 to 4: mode A
PoE Budget
• 120 W
• Up to 30 W per port
Physical Parameters
Power Input
• 48-55 V DC / 2.7 A terminal block dual input
• External power adapter* (48-55 V DC / 2.5 A output)
Power Consumption
• Maximum: 126.3 W (PoE on) / 6.3 W (PoE off)
• Standby: 2.49 W
Heat Dissipation
• 123.16 W (420.5 BTU/hr)
MTBF
• > 200,000 hours
Acoustic
• 0 dB
Ventilation
• Fanless
Surge Protection
• Built-in 6 KV surge protection on copper ports
Dimensions
• 108 x 44 x 138 mm
Weight
• 0.63 kg
Temperature
• Operating: -40° to 75°C
• Storage: -40° to 85°C
Humidity
• Operating: 5% to 95% non-condensing
• Storage: 5% to 95% non-condensing
Certificates
• RoHS
Safety
• cUL
• CB
• CE
• BSMI
EMI
• CE Class A
• VCCI Class A
• FCC Class A
• IC
• BSMI
• RCM
* Not included.
Sertifikatai
Informacija užsakymui
DIS-100G-06P Industrial Switch with 4x10/100/1000Base-T PoE Ports and 2x1000Base-X SFP Ports
