DSS-100E-9P
9-Port 10/100 PoE Unmanaged Surveillance Switch
Aprašymas
The DSS-100E-9P is a member of D-Link’s premier PoE Surveillance Switch family. These surveillance switches are the safest, most reliable and all around best solutions for your surveillance deployments. Supporting long range power delivery and upholding strict surge protection standards, the DSS-100E-9P 9-Port 10/100 PoE Unmanaged Surveillance Switch provides the ideal solution for your surveillance and security systems.
Surveillance-Minded DIP Switch
Effortlessly adjust the DSS-100E-9P’s operation configuration with a dual-mode DIP switch, conveniently located on the device’s front panel. D-Link’s DSS-100E-9P 9-Port PoE Unmanaged Surveillance Switch has two operating modes; Standard and Isolate modes, each with their own use cases. Standard mode optimally is for connections up to 100 m, supporting 10/100 Mbps per port with priority to ports 1-4 to optimize port cache. Isolate mode prevents port to port communications, permitting ports 1-8 to communicate solely through port 9, where strengthened security measures are implemented.
Auto detection for long range deployment
The DSS-100E-9P makes life easy; no DIP switch configuration and no restart required. The DSS-100E-9P can simply detect long range requirements, then automatically activate extended mode without any manual configuration. It can provide power delivery up to 250 m without the need for PoE extenders.* This feature not only streamlines PoE set up, but also cuts down on your deployment’s installation expenses.
Reliable Protection on Every Port
The DSS-100E-9P 9-Port 10/100 PoE Unmanaged Surveillance Switch supports 6kV surge protection to defend your surveillance network against lightening and other incidents resulting in overvoltage. This prevents PoE devices from damage and ensure no interuptions or blackouts in your surveillance systems.
Gigabit Uplink Connection
The DSS-100E-9P is equipped with one Gigabit uplink port, giving you the power to expand and secure your nework. This will provide sufficient bandwidth and ensure smooth transmission performance when connecting to an NVR or another switch.
*This device can support up to 250 m power delivery with CAT5e cable, but transmission speeds will drop to 10 Mbps or below.
Bendros charakteristikos
Interface
• 8 x 10/100 Mbps Fast Ethernet ports
• 1 x 10/100/1000 Mbps Ethernet port
Port Standards & Functions
• IEEE 802.3 compliant
• IEEE 802.3u compliant
• IEEE 802.3ab compliant
• IEEE 802.3af/802.3at compliant
• IEEE 802.3x Flow Control
• Auto MDI/MDIX adjustment for all ports
Performance
Switching Capacity
• 3.6 Gbps
Switching method
• Store and forward
MAC Address Table Size
• 2K Entries
Maximum 64-byte Max.packet Forwarding Rate
• 2.6784 Mbps
Packet Buffer
• 128 KB
LEDs
• Power (per device)
• Link/Activity/Speed (per port)
• PoE OK/PoE Fail (per PoE port)
PoE Standard
• IEEE 802.3af
• IEEE 802.3at
PoE Capable Ports
• Ports 1 to 8
PoE Power Budget
• 92 W (30 W max. per PoE port)
Physical/Environmental
MTBF (Hours)
• 52 308 hours
Acoustic
• 0 dB
Heat Dissipation
• Max: 34.1 BTU/hr
• Standby: 10.7 BTU/hr
Power Input
• DC power adapter: 51 V / 2 A
Power Consumption
• Maximum Power Consumption: 113.4 watts (PoE on), 4.57 watts (PoE off)
• Standby Power Consumption: 3.12 watts (100 V), 3.5 watts (240 V)
Surge Protection
• Up to 6 kV on all Ethernet ports
Dimensions (W x D x H)
• 177 x 104 x 26 mm
Weight
• 0.41 kg
Ventilation
• Fanless
Operating Temperature
• 0 to 40 °C
Storage Temperature
• -40 to 70 °C
Operating Humidity
• 0% to 95% non-condensing
Storage Humidity
Certificates
• CE, FCC, RCM, RoHS
Safety
• LVD
Sertifikatai
Informacija užsakymui
DSS-100E-9P/B1A  9-Port 10/100 PoE Unmanaged Surveillance Switch
Paveikslas
DSS-100E-9P/B1
Vaizdas iš priekio
Vaizdas iš dešinės
Vaizdas iš galo
Parsisiuntimui
Taip pat žiūrėkite
