DXS-5000-54SProjektams
48-port 10G SFP+, 6-port 40G QSFP+ interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
Aprašymas
The D-Link DXS-5000-54S Data Center Switch is a high-performance switch that features high port density, routing, and ultra-low latency, designed to be deployed as Top-of-Rack (ToR) or leaf-spine switch in data center applications. Combined with ONIE support and increased cost-efficiency, the DXS-5000-54S forms a flexible long-term solution for managing and expanding data center infrastructures in a Software-Defined Networking (SDN) environment.
Open Networking
The DXS-5000-54S switch supports open networking, providing IT professionals with innovative third-party operating systems and software options. This lowers costs by separating software from hardware and increases network agility and flexibility. With support for standards-based tools and standards-based applications, open networking simplifies scalability and future-proofs the network.
As bare metal switches, the DXS-5000-54S switch ships pre-loaded with Open Network Install Environment (ONIE). ONIE is an open source install environment that acts as an enhanced boot loader. This small Linux operating system allows administrators to install the network operating system(s) of their choice as part of the data center provisioning process in the same manner that servers are provisioned.
High Availability and Reliability
The DXS-5000-54S switch features a modular fan and power supply design for a high availability architecture. The hot-swappable design means that fans and power supplies can be replaced without affecting switch operation. Load sharing enables both power supplies to evenly distribute load to increase reliability and lifetime. Meanwhile, 1+1 redundancy minimizes downtime in case of a single power supply failure.
Flexibility and Versatility
Open Network Install Environment (ONIE) support means the switch can be easily integrated in existing network ecosystems using a variety of supported third-party Network Operating Systems (NOSs) for optimal compatibility. Furthermore, the ability to pick and choose software based on practical requirements eliminates the restrictions imposed by vendor-locked software environments.
Cost-Efficient with Dedicated Support
Compared to traditional switches, the DXS-5000-54S offers a more cost-efficient solution through a lower initial purchasing cost combined with a reduced long-term Total Cost of Ownership (TCO). The DXS-5000-54S switch features front-to-back and back-to-front airflow which optimizes air circulation inside the rack and facilitates the building of energy-efficient data centers by separating the hot and cold aisles. The switch also features built-in smart fans; internal heat sensors monitor and detect temperature changes, and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run more slowly, reducing the switch’s power consumption and noise.
Data Center and Virtualization Features
Data Center Bridging (DCB) is an essential set of enhancements to Ethernet for networking in data center environments. The D-Link OS for the DXS-5000-54S switch supports several core components of Data Center Bridging (DCB), such as IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau, and VXLAN. IEEE 802.1Qbb (Priority-based Flow Control) provides flow control on specific priority levels to ensure there is no data loss during network congestion. IEEE 802.1Qaz (Enhanced Transmission Selection) manages the allocation of bandwidth amongst different traffic classes. IEEE 802.1Qau (Congestion Notification) provides congestion management for data flows within network domains
to avoid congestion. Meanwhile, VXLAN allows network administrators to deploy larger and more flexible VLAN architectures. Using a 24-bit ID, VXLAN greatly increases the number of simultaneous VLANs. Compared to the 4096
limit of traditional VLAN protocols, VXLAN enables the deployment of up to 16 million isolated logical networks across Layer 3 subnets, to accommodate the increasing scale of virtualized cloud environments.
Complete Layer 2/3 Functionality
The DXS-5000-54S switch features a complete L2 and L3 feature set to meet the demands of data center applications. Layer 2 features include L2 switching, L2 multicast, advanced Quality of Service (QoS), and robust security features.
Meanwhile, the DXS-5000-54S offers advanced L3 routing for enterprise integration, including OSPF, BGP, Graceful Restart, Bidirectional Forwarding Detection (BFD), and L3 multicast.
Bendros charakteristikos
Interfaces
• 48 x 10G SFP+ ports
• 6 x 40G QSFP+ ports
• 1 x USB 2.0 port
• 1 x mini-USB console port
• 1 x 10/100/1000BASE-T RJ-45 port
Switching Capacity
• 1.44 Tbps
Max. Forwarding Rate
• 1,071 Mpps
Packet Buffer Memory
• 12 MB
MAC Address Table
• 288K
Software Features (D-Link OS)
L2 Features
• 802.3ad Link Aggregation:
Max. 64 groups per device
Max. 32 ports per group
• Spanning Tree Protocol (STP):
802.1D STP
802.1w RSTP
802.1s MSTP
BPDU Filter/Guard
Loop Guard
TCN Guard
Root Guard
• Supports 802.3x Flow Control
• Jumbo frame: up to 9 Kb
• Port mirroring:
Supports One-to-One, Many-to-One
Supports mirroring for Tx/Rx/Both
Supports up to 4 mirroring groups
• Flow mirroring:
Supports Rx mirroring
• VLAN mirroring
• RSPAN
• Multi-Chassis Link Aggregation (MLAG)
L2 Multicast Features
• IGMP Snooping:
IGMP Snooping v1/v2/v3
IGMP Fast Leave
Supports up to 256 IGMP groups
Per-VLAN IGMP Snooping
IGMP Snooping Querier
• MLD Snooping:
MLD Snooping v1/v2
Supports up to 256 MLD groups
Per-VLAN MLD Snooping
MLD Snooping Querier
L3 Features
• IP interfaces:
Supports 128 IP interfaces
• ARP:
Supports 6K ARP entries
Supports 256 static ARP entries
• IPv6 Neighbor Discovery (ND):
Supports up to 2560 ND entries
Supports up to 32 static ND entries
• Gratuitous ARP
• VRRP v2
• UDP Helper
• ICMP Router Discovery Protocol (IRDP)
• Equal-Cost Multi-Path (ECMP)
• IPv6 Tunneling:
6to4
GRE
• IPv4/IPv6 Loopback interface
L3 Routing
• Static routing:
Max. 64 IPv4 entries
Max. 64 IPv6 entries
Supports Equal-Cost-Multi-Path Route (ECMP)
• OSPF:
OSPF v2/v3
Stub/NSSA Area
OSPF Passive Interface
Text/MD5 authentication
• Supports 12K hardware routing entries shared by IPv4 and IPv6
• Supports 20K hardware L3 forwarding entries shared by IPv4 and IPv6
• IPv4/IPv6 Default Route
• Null Route
• Route Preference
• Route Redistribution
• Graceful Restart (GR) for OSPF
• Grace Restart (GR) Helper for RIP
• Bidirectional Forwarding Detection (BFD) for OSPF
• BGP:
BGP4/BGP4+
Max. 256 BGP neighbors
Supports MD5 authentication
• Policy-based Route (PBR)
L3 Multicast Features
• IGMP v1/v2/v3
• MLD v1/v2
• DVMRP v3
• PIM-SSM
• SSM Mapping for IPv4/IPv6
• PIM-SM IPv4/IPv6
• PIM-DM IPv4/IPv6
• IGMP/MLD proxy
VLAN
• 802.1Q
• Port-based VLAN
• Multicast VLAN (ISM VLAN for IPv4/IPv6)
• Private VLAN
• Double VLAN (Q-in-Q)
• VLAN groups:
Max. 4K VLAN groups
Max. 1~4093 VLAN IDs
Security
• Broadcast/unicast/multicast control
• SSH:
Supports v1/v1.5/v2.0
Supports IPv4/IPv6 access
Configurable TCP port number
• Port security:
Supports up to 600 MAC addresses per port
• DoS attack prevention
• Traffic segmentation
• IP Source Guard
• DHCP Snooping
• IPv6 Snooping
• DHCP Server Screening
• Dynamic ARP Inspection (DAI)
• IPv6 Route Advertisement (RA) Guard
• Duplicate Address Detection (DAD)
• BPDU Attack Protection
Authentication, Authorization, Accounting (AAA)
• 802.1X authentication:
Supports port-based access control
Supports host-based access control
Identity-driven policy assignment
Dynamic VLAN assignment
QoS assignment
ACL assignment
• Guest VLAN
• RADIUS authentication
• TACACS+ authentication
• MAC-based Access Control (MAC):
Supports port/host-based access control
Compatible with RADIUS server authentication
• Authentication for management access
• Privilege level for management access
• Authentication database failover
• RADIUS/TACACS+ accounting
• Max. of 8 priority queues per port
• Queue handling:
Strict Priority (SP)
Weighted Deficit Round Robin (WDRR)
• Congestion control:
Weighted Random Early Detection (WRED)
• Bandwidth control
Queue-based bandwidth control; min. granularity of 1% of the port speed
• Three Color Marker:
Two Rate Three Color Marker (trTCM)
Single Rate Three Color Marker (srTCM)
• Class of Service (CoS):
Switch port
Outer 802.1p priority
ToS/IP preference
DSCP
• Policy Map:
Remark 802.1p priority
Remark ToS/DSCP
Rate limiting
Data Center Features
• Open Network Install Environment (ONIE)
• FCoE Initialization Protocol (FIP) Snooping
• 802.1Qau Congestion Notification (CN)
• 802.1Qbb Priority-based Flow Control (PFC)
• 802.1Qaz Enhanced Transmission Selection (ETS)
• Data Center Bridging Exchange (DCBX)
• OpenFlow v1.3
• Open API
• Supports Puppet/Chef
• Virtual eXtensible Local Area Network (VXLAN)
Access Control List (ACL)
• MAC Access List based on:
802.1p priority mask
VID mask
Source/destination MAC address mask
Ether Type mask
• IP Access List based on:
Source/destination IP address mask
IP preference/ToS mask
TCP/UDP port number mask
• IPv6 Access List based on:
• CPU interface filtering:
Max. 1023 rule entries
• Time-based ACL
• Max. ACL entries:
Max. ingress ACL entries: 16K
Max. egress ACL entries: 16K
Max. number of access control lists: 100
Max. VLAN access maps: 24
Max. ACL rule entries: 1K
Management
• Industry-standard CLI
• Telnet server for IPv4/IPv6 access
• TFTP client for IPv4/IPv6
• FTP client for IPv4/IPv6
• Secure FTP (SFTP) client for IPv4/IPv6
• Multiple images
• Dual configurations
• SNMP:
Supports SNMP v1/v2c/v3
Supports IPv4/IPv6
• SNMP traps
• System log for IPv4/IPv6 Syslog server
• Command logging
• SMTP
• RMON v1:
Supports 1/2/3/9 groups
• DHCP/BOOTP Client support for IPv4/IPv6 DHCP/BOOTP server
• DHCP Relay:
Supports IPv4/IPv6
Option 82
Supports user-defined TLV for Option 82
• Event log
• DNS client
• SNTPv4
• LLDP/LLDP-MED
• CDP
• UDLD
• sFlow v5
• DHCP auto-configuration
• DHCP auto-image
• Flash file system
• DNS client for IPv4/IPv6
• Debug command
• Password recovery/encryption
• Supports IPv4/IPv6 Ping/Traceroute
Physical Parameters
Power Input
• 1+1 redundant power supply design
• Input: 100 to 240 V AC, 50/60 Hz
Maximum Power Consumption
• 295 W
Heat Dissipation (Max.)
• 1006.58 BTU/hr
Fans
• 4 fans
Acoustics
• Max: 74 dB / Min: 62 dB
MTBF (hours)
• 205,000
Dimensions (W x D x H)
• 440 x 406 x 44 mm
Weight
• 9 kg
Temperature
• Operating: 0 to 45 °C
• Storage: -40 to 70 °C
Humidity
• Operating: 5% to 95% non-condensing
• Storage: 5% to 95% non-condensing
Safety
• cULus
• CCC
• BSM
• CB
• CE
EMI/EMC
• FCC/IC
• CCC
• CB
• CE
• BSMI
Sertifikatai
Informacija užsakymui
DXS-5000-54S 48-port 10G SFP+, 6-port 40G QSFP+ interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
