DES-1009MP
9-Port 10/100 PoE Unmanaged Desktop Switch
Aprašymas
The DES-1009MP is an unmanaged 9-port PoE Switch to power your devices such as wireless access points and IP cameras with up to 30 W per port (117 W total PoE budget), and a Gigabit uplink port that allows sufficient bandwidth for uplink connectivity. To streamline network operation, the DES-1009MP is an affordable desktop solution with convenient functionalities such as Auto-negotiation and Store-and-Forwarding which is minimizing data transmission errors. Fanless Design provides enhanced heat dissipation for silent operation.
High Performance
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables. Auto-negotiation on each port intelligently adjusts the port speed for compatibility with the connected device. The Gigabit uplink port provides high data throughput to connect remote networks and can ensure uncongested access to high-bandwidth network devices such as surveillance NVRs. The DES-1009MP supports a wide array of Plug-&-Play features providing fast configuration-free deployment.
Power over Ethernet
8 Fast Ethernet ports are PoE-equipped, conveniently supplying up to 30 W of power per port for connected PoE devices with a maximum PoE budget of 117 W, eliminating the need for access to power outlets.
Reliable Protection on Every Port
The DES-1009MP is shielded from unexpected electrical surges such as from lightning strikes with 6kV surge protection, safeguarding your switch from internal circuit damage.
Bendros charakteristikos
Interfaces
• 8 x 10/100 Mbps Ethernet ports
• 1 x 10/100/1000 Mbps Ethernet port
Standards
• IEEE 802.3ab Gigabit Ethernet
• IEEE 802.3x Flow Control Support
Media Interface Exchange
Auto MDI/MDIX adjustment for all ports
LEDs
• Link/Activity (per port)
• Power (per device)
• PoE Status (ports 1-8)
Functionality
Max. Packet Forwarding Rate
• 2.68Mpps
Switching Fabric
3.6 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 2K entries per device
Flash Memory Size
• 8Kbits
Packet Buffer Size
• 1Mbits
PoE
PoE Standards
• IEEE 802.3af
• IEEE 802.3at
PoE ports
• Ports 1 to 8
PoE Power Budget
• 117 W
Physical/Environmental
Power Input
• 51V 2.5A
Power Consumption
• Maximum Power Consumption: 127W
• Standby Power Consumption: 10W
Heat Dissipation
• 433.34 BTU/h
Acoustics
• 0 dB
Surge Protection
• 6kV
Ventilation System
• Fanless
Temperature
• Operating: 0° to 40°C
• Storage: -10° to 70°C
Humidity
• Operating: 0 to 95% non-condensing
• Storage: 0 to 95% non-condensing
Dimensions
• 177*104*26mm
Weight
• 0.396 kgs
EMI/EMC
• CE
Comply with RoHS 6
• Yes
Safety
• LVD
Sertifikatai
Informacija užsakymui
DES-1009MP 9-Port 10/100 PoE Unmanaged Desktop Switch
