DVG-N5402GProje
Wireless Gigabit router with support for 3G/LTE, 2 FXS ports, 1 PSTN port (lifeline) and USB port
Nereden Alınır
Tanımlama
Voice The VoIP router is equipped with two FSX ports which allow connection of analog phones for calls via the Internet and one PSTN port (lifeline) for connecting to the local telephone network. USB port The router includes a USB port for connecting a USB-modem with which You can quickly connect to the Internet. In addition, You can connect to the USB port on the router USB-drive, which will be used as a network drive, or printer. The wireless interface Using wireless router DVG-N5402G, You can quickly arrange high-speed wireless network in your home or office, providing access to the Internet to computers and mobile devices almost anywhere (within range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11 b, 802.11 g, and 802.11 n (with speed wireless connection up to 300 Mbps). The router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtering devices by MAC address, and allows the use of technology WPS and WMM. In addition, the device is equipped with a button to disable/enable the Wi-Fi network. If necessary, for example, leaving home, You can turn off the router's wireless network just one press of button, devices connected to LAN ports of the router will remain in the network. Safety Wireless router DVG-N5402G includes a firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to Your network, and block access to unwanted websites for users Your local network. Easy setup and update To configure the wireless router DVG-N5402G the userfriendly web-interface (available in several languages). Now You can easily update the firmware: the router itself finds approved firmware on the update server D-Link, and notifies the user ready to install it.
Genel Özellikler
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DVG-N5402G/A1
Back view
View from the right
Front view
İndir
Destek Merkezi
