DVG-2032SEOL EOS
Tanımlama
DVG-2032S/16CORU * is an ideal solution for Internet telephony, dynamic business. This gateway converts voice traffic into data packets for transmission over the Internet, and is fully compatible with the services of Internet telephony SIP. Gateways are high-density and low-cost, provide convenience and guaranteed savings for companies in need of frequent long-distance and international business calls.
Modular Solution
With the ability to install add-on module (DVG-2032S/16MORU), DVG-2032S/16CORU allows you to easily double the number of available ports FXS (16 to 32). This makes it possible to increase the capacity of the system as the number of users, storing the customer's investment.
Cost reduction. Investment protection
DVG-2032S/16CORU Gateway provides an easy and inexpensive upgrade networks to support Internet telephony, allowing users to save previously purchased phones and fax machines. Investment protection is achieved through the use of existing infrastructure and the possibility of its gradual modernization.
Guaranteed quality of voice
gateway DVG-2032S/16CORU provides voice and fax messages in accordance with generally accepted international standards of voice and data. Support for Quality of Service (QoS) provides the communication quality comparable to analog telephony.
Call Functions
• Hold, Call waiting, call forwarding, call forwarding • Easy control with the registration of telephone calls • Visual Caller ID (Caller ID)
Setup / Upgrade
• Easy setup IVR or web-interface • Software update web-based interface
