Hızlı Arama
Ürün Özellikleri:
Modular VoIP Gateway 16-port FXS, 1-port 10/100 Mbit / s Ethernet WAN, 1-port 10/100 Mbit / s Ethernet LAN and one open slot for an optional module for 16 FXS ports
EOL
Genel Özellikler:
Fiziksel Özellikler
    Device Interfaces
  • 16 port FXS c 1 RJ-21 connector
  • 1 open slot for an optional module
  • Port 10/100BASE-TX RJ-45 WAN
  • Port 10/100BASE-TX RJ-45 LAN Support for additional modules
  • DVG-2032S/16MORU Connection Types
  • DHCP-Client
  • PPPoE-client
  • PPTP
  • Cable BigPond (Australia) Routing Features
  • DHCP-server
  • Virtual Server
  • DMZ
  • Filtering based on port, IP, MAC, URL
  • RIP v.1, v.2, Static route
  • DDNS: DynDns.org, TZO, 3322.ORG
  • NAT Traversal: pass-through NAT, client STUN, UPnP Phone Book
  • The management server phonebook, up to 200 entries IAD SIP
  • Join the port "By Port" "By machine"
  • Dialing in the standard E.164
  • Redundant SIP PROXY (registration)
  • SIP PING
  • CLIR (Anonymous Caller ID)
  • Feature hot line / warm line
  • The functions of the group call
  • Hold, Call Waiting
  • Call forwarding: with accompaniment / unaccompanied
  • Call forwarding: unconditional, busy, no answer
  • 3-way conference
  • T.30 fax pass-through
  • T.38 fax relay
  • Adjustable fax tone detection
  • Out of band DTMF: RFC2833, SIP INFO Voice Features
  • G.711 a / u, G.726 (32K), G.729A, G.723.1
  • Adjustable jitter-buffer
  • Variable packet size (depending on the codec)
  • Detection and Noise Reduction
  • Echo
  • The local phone book can call other VoIP-device without registration
  • Speed ​​Dial
  • Call Filter - accept / reject calls from on IP-addresses
  • ID-generation FXS-calls: DTMF, FSK (Bell core / ETSI)
  • Support the FLASH control
  • Web-based interface and Telnet, IVR Indicators
  • Power
  • Reset
  • Alarm
  • Run
  • From 1 to 32
The physical parameters
    Input voltage
  • 90-260 VAC, 50/60 Hz
  • The internal power supply Dimensions
  • 442 x 330 x 43 mm
  • Installation in a 19 "rack, 1U Height Weight
  • 4.1 kg Operating temperature
  • 0 to 45 C Storage Temperature
  • -25 To 75 C Humidity
  • Up to 95% non-condensing Emission (EMI)
  • FCC Class A
  • CE Safety Certification
  • UL
Ürünler | Destek  | Haberler  | Hakkında |
