DGE-560SXEOL
PCI Express Network Adapter 1-port 1000Base-SX with LC-Duplex connector
Tanımlama
High-performance Gigabit Ethernet network adapter for the bus PCI Express D-Link DGE-560SX allows you to increase network performance with support for PCI Express (PCI-E) and optical connection.
PCI Express interface
In full-duplex adapter DGE-560SX supports data rates up to 2 Gbit / s, providing high bandwidth between the adapter and the server. With fault tolerance, reliability and performance, DGE-560SX is the perfect solution for connecting input and output devices to a wide range of storage servers. Having to replace a PCI and PCI-X, architecture PCI Express bus eliminates many of the drawbacks of architectures with parallel PCI buses and PCI-X. Due to fewer contacts and less power consumption, DGE-560SX adapter allows to reduce the power consumption of the entire system.
Advanced Features
DGE-560SX supports Jumbo-frames up to 9 KB, and the specification ACPI (Advanced Configuration and Power Management) to enable OSPM (configuration and power management controlled by the operating system). In addition, the adapter supports SNMP-agent management via SNMP.
VLAN and QoS support
Network Adapter DGE-560SX supports embedded filtering of tagged Ethernet-VLAN frame in accordance with standard IEEE 802.1Q. This allows the server to operate in a flexible and secure network, established in accordance with the standards. The adapter also supports priority queues, according to the protocol 802.1p, for the transmission of delay-sensitive data (eg, voice and video).
Fiber optic connection
Supporting data rates up to 2000 Mbit / s fiber-optic cable in full duplex mode, the adapter DGE-560SX provides enough bandwidth when connecting to the server. Hardware calculation headers and checksums IP-packets offloads the CPU of network nodes, and improve network performance.
