Hızlı Arama
Ürün Özellikleri:
Wireless VPN Firewall
EOL
Genel Özellikler:
Interface Ethernet
• 2 10/100/1000 Mbps WAN Ports
• 4 10/100/1000 Mbps LAN Ports
Wireless
• 802.11a/b/g/n (Dual Band)
• 3 Detectable 2dBi Omni-Directional Antennas
USB
2 USB 2.0
Console
RJ-45
System Performance8
• Firewall Throughput7: 130 Mbps
• VPN Throughput9: 70 Mbps
• Concurrent Sessions: 60,000
• New Sessions (per second): 600
• Firewall Policies: 600
Networking
• DHCP Server/Client
• DHCP Relay
• IEEE802.1q VLAN
• VLAN (Port-Based)
• IP Multicast IGMP Proxy
• IPv6
• Route Failover
• 3G Redundancy
• Outbound Load Balancing
Wireless
• Multiple Service Set Identifier (SSID)
• Service Set Identifier (SSID) to VLAN Mapping
• Wireless Security:
  Wired Equivalent Privacy (WEP)
  Wi-Fi Protect Setup (WPS)
  Wi-Fi Protected Access
  Personal (WPA-PSK)
  Enterprise (WPA-EAP)
  Wi-Fi Protected Access version 2 – Personal (WPA-PSK)
  Wi-Fi Protected Access version 2 – Enterprise (WPA-EAP)
Virtual Private Network (VPN)
• VPN Tunnels: 70
• Encryption Methods: DES, 3DES, AES, Twofish, Blowfish, CAST-128, NULL
• IPSec/PPTP/L2TP Server
• IPSec NAT Traversal
• Dead Peer Detection
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
SSL Virtual Private Network (SSL VPN)
• SSL VPN Tunnel: 20
• SSL Encryption Methods: DES, 3DES, AES
• SSL Message Integrity: MD5, SHA1
Bandwidth Management
• Max. Bandwidth Control
• Priority Bandwidth Control
  Port-Based QoS
  3 Classes
System Management
• Web-based User Interface: HTTP, HTTPS
• Command Line
• SNMP v1, v2c, v3
Fiziksel Özellikler
Power Supply Internal
• Power Supply Unit
• DC 12 V / 2.5 A
Max. Power Consumption
19.3 W
Dimensions (L x W x H)
180 x 280 x 44 mm
Operation Temperature
0 to 40 °C
Storage Temperature
-20 to 70 °C
Operation Humidity
5% to 95% Non-condensing
EMI/EMC
FCC Class B, CE Class B, VCCI, C-Tick, IC
Safety
cUL, LVD(EN60950-1)
MTBF
260,000 hours
6 Available with future firmware upgrade.
7 The maximum Firewall plaintext throughput is based on RFC2544 testing methodologies.
8 Actual performance may vary depending on network conditions and activated services.
9 VPN throughput is measured using UDP traffic with a 1420 byte packet size, adhering to RFC2544.
Ürünler | Destek  | Haberler  | Hakkında |
