Hızlı Arama
Ürün Özellikleri:
Küçük işletmeler için NetDefend UTM Firewall
EOL EOS
Genel Özellikler:
Fiziksel Özellikler
The interface with the user:
  • 1 10/100/1000 Ethernet WAN port
  • EthernetDMZ 1 10/100/1000 port (adjustable)
  • 5 10/100/1000 Ethernet LAN ports
  • 2 USB ports (reserved)
  • The console port is an RJ-45
System Performance:
  • Firewall Performance 2 : 150 Mbps
  • VPN Performance 3 : 45 Mbps
  • IPS Performance 4 : 60 Mbps
  • Antivirus Performance 4 : 35 Mbps
  • Parallel sessions: 25000 5
  • New sessions: 2000 (second)
  • Number of rules 500
Firewall features:
  • Transparent mode
  • NAT, PAT
  • H.323 NAT Traversal
  • Policy according to the schedule
  • Application Layer Gateway (ALG)
  • Proactive Network Protection
Network functions:
  • DHCP client / server
  • DHCP relay
  • Routing policies based
  • IEEE 802.1Q VLAN: up to 8
  • Port-based VLAN
  • IP Multicast: IGMP v3
VPN:
  • Encryption (DES / 3DES / Twofish / Blowfish / CAST-128)
  • 100 individual VPN tunnels
  • PPTP/L2TP server
  • Mode Hub and Spoke
  • IPSec NAT Traversal
  • SSL VPN (will work in the future)
Load balancing:
  • Outgoing traffic balancing
  • Server load balancing algorithm: Round-robin, Weight-based Round-robin, Destination-based, Spill-over
  • Traffic forwarding channel termination (Fail-over)
Bandwidth Management:
  • Traffic Shaping policies based
  • Guaranteed Bandwidth
  • The maximum bandwidth
  • Bandwidth prioritization
  • Dynamic Bandwidth Allocation
Resistance to interference:
  • WAN channel reservation
Prevention and Intrusion Prevention System (IDS / IPS)
  • Automatic template update
  • Protection against DoS and DDoS attacks
  • Information about the attacks in e-mail. post
  • Advanced IDP / IPS subscription (sold separately)
Content filtering:
  • HTTP type: black / white list of URLs
  • Set of commands type: Java Cookie, ActiveX, VB
  • E-mail. mail type: black / white e. Mailing List
  • External database content filtering
Antivirus protection:
  • Antiviral scanning in real time
  • Unlimited document size
  • VPN tunnel scanning
  • Compressed documents required
  • Antiviral codes: Kaspersky
Physical parameters
Meals:
  • Internal power supply
Dimensions:
  • 280 x 180 x 44 mm
  • Suitable for installation in 11-inch rack
Working temperature:
  • 0 º to 40 º C
Storage temperature:
  • -20 º to 70 º C
Working humidity:
  • 5% to 95% without condensation
Average working hours without a crash:
  • 186,614 hours.
Electromagnetic Compatibility Certificates:
  • FCC Class A
  • CE Class A
  • C-Tick
  • VCCI
Security Certificates:
  • UL
  • LVD (EN60950-1)
1 Actual performance may vary depending on network conditions and service activity.
2 Maximum capacity RFC 2544-based.
3 VPN traffic throughput measured using UDP traffic, the packet size is 1420 according to RFC 2544th
4 IPS and antivirus performance test conducted according to the HTTP protocol, by adding a run for IXIA IxLoad 1 Mb file. Tested with multiple flows through multiple port pairs.
5 Productivity determined using the software version 2.27.00 and later.
6 The function works if the DMZ port is set to the WAN port.
7 Compatible with the following D-Link SFP optical transducer modules: DEM-310GT, DEM-311GT, DEM-312GT2, DEM-314GT, DEM-315GT, DEM-330T, DEM-330R, DEM-331T, DEM-331R, DGS- 712.
Ürünler | Destek  | Haberler  | Hakkında |
