Hızlı Arama
Ürün Özellikleri:
4G LTE Router
Genel Özellikler:
Hardware
Processor
• MT7620N (600MHz)
RAM
• 64MB, SDRAM
Flash
• 16MB, SPI
Interfaces
• Slot for (U)SIM card (mini-SIM)
• 10/100BASE-TX WAN port
• 4 10/100BASE-TX LAN ports
LEDs
• SIGNAL STRENGTH
• SMS
• LAN
• POWER
• 2G/3G
• 4G
• WLAN
Buttons
• POWER ON/OFF button to power on/power off
• WPS button to set up wireless connection
• RESET button to restore factory default settings
Antenna
• Two detachable LTE/3G antennas (3dBi gain)
• Two internal Wi-Fi antennas (3dBi gain)
MIMO
• 2 x 2
Power connector
• Power input connector (DC)
Software
WAN connection types
• LTE
• PPPoE
• IPv6 PPPoE
• PPPoE Dual Stack
• Static IP / Dynamic IP
• Static IPv6 / Dynamic IPv6
• PPPoE + Static IP
• PPPoE + Dynamic IP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• Support of IEEE 802.1X for Internet connection
• DHCP server/relay
• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
• DNS relay
• Dynamic DNS
• Static IP routing
• Static IPv6 routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• WAN failover
• Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
Firewall functions
• IP filter
• IPv6 filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Built-in Yandex.DNS web content filtering service
VPN
• IPsec tunnels
Management
• Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
• Bilingual web-based interface for configuration and management (Russian/English)
• Support of logging to remote host
• Ping function
• Traceroute utility
• TR-069 client
LTE Module Parameters
LTE connection rate1
• Downlink: up to 150Mbps
• Uplink: up to 50Mbps
Supported frequencies2
• LTE
800/900/1800/2600MHz
• UMTS/HSDPA/HSUPA/HSPA+/DC-HSPA+
900/2100MHz
Power Class 3
• GSM/GPRS/EDGE
850/900/1800/1900MHz
Functions
• Auto connection to available type of supported network (4G/3G/2G)
• Auto configuration of connection upon plugging in SIM card
• Enabling/disabling PIN code check, changing PIN code
Wireless Module Parameters
Standards
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of client mode
• WMM (Wi-Fi QoS)
• Information on connected Wi-Fi clients
• Advanced settings
Wireless connection rate
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
Transmitter output power
• 15dBm
Receiver sensitivity
• 802.11b
-86dBm at 11Mbps
• 802.11g
-81dBm at 54Mbps
• 802.11n
HT20
-71dBm at MCS15
HT40
-67dBm at MCS15
Modulation schemes
• 802.11b: DSSS, BPSK, QPSK, CCK
• 802.11g: OFDM
• 802.11n: OFDM
Physical Parameters
Dimensions (L x W x H)
• 190 x 112 x 22 mm (7.5 x 4.4 x 0.9 in)
Weight
• 295 g (0.7 lb)
Operating Environment
Power
• Output: 12V DC, 1A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -10 to 70 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 0% to 95% (non-condensing)
Delivery Package
• Router DWR-921
• Power adapter DC 12V/1A
• Ethernet cable (CAT 5)
1 Data rates are theoretical. Data transfer rate depends on network capacity and signal strength.
2Supported frequency bands are dependent on regional variants.
Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
