DIR-816LEOL EOS
AC750 mydlink desteği ile dual-band kablosuz yönlendirici
Nereden Alınır
Tanımlama
Dual-band wireless router with support for mydlink AC750 is an affordable and effective solution to create a wireless network that combines the characteristics of the latest technology 802.11ac, providing work in two frequency bands, and the ability to connect to the Fast Ethernet port to provide continuous network operation. Wireless AC technology provides extended wireless coverage and connection, and advanced security features - reliable protection of your network and data.
Continuous operation in two frequency bands, thanks to technology Wireless AC
Router DIR-816L provides a common wireless speed up to 750 Mbit / s and increased the range of the wireless network. This device also supports simultaneous operation in two frequency bands for maximum performance wireless network. Browse Web-page, play online and communicate with your friends using the 2.4GHz frequency, while the frequency of 5 GHz band can be used for streaming media content. Moreover, each frequency band can be operated as a separate network of Wi-Fi, allowing you to tailor the network to meet your needs. You can customize the guest area to provide visitors with access to the Internet, but at the same time keep the data available to them in the local network.
mydlink SharePort ™ - your personal cloud storage
Connect the USB-drive to the DIR-816L for the immediate establishment of a personal repository to gain remote access to the documents, movies, photos or music with mydlink SharePort. Save space on your mobile device thanks to streaming your favorite shows and music or download certain episodes or songs to your device for offline playback.
Mydlink service
DIR-816L supports cloud service mydlink, which provides the ability to remotely access, view and control the device. The service mydlink you can view information about the users who are connected to the router, change the settings to block unauthorized users from any computer or mobile platforms iOS and Android, connected to the Internet. In addition, parents can view and control the sites visited by their children.
Easy to install and configure security
Provide users share an Internet connection is not difficulty: just open the Web-browser to access the setup wizard, and follow a few simple steps. Protect your wireless network using encryption, WPA / WPA2, in a matter of minutes using the setup wizard or use technology, Wi-Fi Protected Setup (WPS), which provides a secure connection of new devices without the need to enter the settings, or create a password. In addition, the built-in firewall protects the network against malicious attacks from the Internet, and access control features allow you to restrict access to your network.
Genel Özellikler
Fiziksel Özellikler
Device Interfaces
• IEEE 802.11ac Wireless Cohort1
• IEEE 802.11a/b/g/n Wireless LAN
• Порт USB 2.0
• Port WAN 10/100 Mbit / s
• 4-port LAN 10/100 Mbit / s
Indicators
• Power
• Internet
• WLAN
• LAN (for each port)
• WPS
Type of antennas
• Two external antennas
Frequency Range
• 2,4 Main City Centre from 2400 to 2483 MGts
• 5 GHz, from 5150 to 5320 MHz, from 5725 to 5850 MHz
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3u
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 и 54 Мбит / с
• IEEE 802.11b: 1, 2, 5,5 и 11 Мбит / с
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 и 54 Мбит / с
• IEEE 802.11n (2.4 GHz / 5 GHz): from 6.5 to 300 Mbit / s (from MCS0 to MCS15)
• IEEE 802.11ac (5 GHz): from 6.5 to 433 Mbit / s
Transmitter output power *
• IEEE 802.11a:
  17 dBm at 6, 9, 12, 18 Mbit / s
  16 dBm at 24 Mbit / s
  15 at 36 Mbit / s
  14 dBm at 48, 54 Mbit / s
• IEEE 802.11b:
  18 ± 2 dBm at 1, 2, 5,5, 11 Mbit / c
• IEEE 802.11g:
  18 dBm at 6, 9 Mbit / s
  17 dBm at 12, 18 Mbit / s
  17 dBm at 24 Mbit / s
  16 dBm at 36 Mbit / s
  15 dBm at 48 Mbit / s
  14 dBm at 54 Mbit / s
• IEEE 802.11n:
2,4 ГГц/HT-20:
18 dBm при MCS0/1/8/9
17 dBm при MCS2 / 3/10/11
16 dBm при MCS4/12
15 dBm при MCS5/13
14 dBm при MCS6 / 7/14/15
2,4 ГГц/HT-40:
17 dBm при MCS0/1/8/9
16 dBm при MCS2 / 3/10/11
16 dBm при MCS4/12
15 dBm при MCS5/13
5 ГГц/HT-20:
17 dBm при MCS0/1/2/3
16 dBm при MCS4
15 dBm при MCS5
14 dBm при MCS6/7
5 ГГц/HT-40:
16 dBm при MCS4
15 dBm при MCS5
14 dBm при MCS6/7
• IEEE 802.11ac (5 ГГц):
HT-20:
16 dBm при MCS4
15 dBm при MCS5
14 dBm при MCS67
12 dBm при MCS8
HT-40:
16 dBm при MCS4
15 dBm при MCS5
14 dBm при MCS6/7
12 dBm при MCS78
11 dBm при MCS9
HT-80:
16 dBm при MCS4
15 dBm при MCS5
14 dBm при MCS6/7
12 dBm при MCS8
11 dBm при MCS9
* The maximum transmitter power will vary in accordance with the rules of the radio-frequency regulation in your country.
Receiver Sensitivity
• IEEE 802.11a:
  -82 DBm at 6 Mbit / s
  -81 DBm at 9 Mbit / s
  -79 DBm at 12 Mbit / s
  -77 DBm at 18 Mbit / s
  -74 DBm at 24 Mbit / s
  -70 DBm at 36 Mbit / s
  -66 DBm at 48 Mbit / s
  -65 DBm at 54 Mbit / s
• IEEE 802.11b:
  -84 DBm at 1 Mbit / s
  -84 DBm at 2 Mbit / s
  -82 DBm at 5.5 Mbit / s
  -79 DBm at 11 Mbit / s
• IEEE 802.11g:
• IEEE 802.11n:
2,4 ГГц/HT-20:
-82 dBm при MCS0
-79 dBm при MCS1
-77 dBm при MCS2
-74 dBm при MCS3
-70 dBm при MCS4
-66 dBm при MCS5
-65 dBm при MCS6
-64 dBm при MCS7
2,4 ГГц/HT-40:
-79 dBm при MCS0
-76 dBm при MCS1
-74 dBm при MCS2
-71 dBm при MCS3
-67 dBm при MCS4
-63 dBm при MCS5
-62 dBm при MCS6
-61 dBm при MCS7
5 ГГц/HT-20:
-82 dBm при MCS0
-79 dBm при MCS1
-77 dBm при MCS2
-74 dBm при MCS3
-70 dBm при MCS4
-66 dBm при MCS5
-65 dBm при MCS6
-64 dBm при MCS7
5 ГГц/HT-40:
-79 dBm при MCS0
-76 dBm при MCS1
-74 dBm при MCS2
-71 dBm при MCS3
-67 dBm при MCS4
-63 dBm при MCS5
-62 dBm при MCS6
-61 dBm при MCS7
HT-20:
-82 dBm при MCS0
-79 dBm при MCS1
-77 dBm при MCS2
-74 dBm при MCS3
-70 dBm при MCS4
-66 dBm при MCS5
-65 dBm при MCS6
-64 dBm при MCS7
-59 dBm при MCS8
-57 dBm при MCS9
HT-40:
-79 dBm при MCS0
-76 dBm при MCS1
-74 dBm при MCS2
-71 dBm при MCS3
-67 dBm при MCS4
-63 dBm при MCS5
-62 dBm при MCS6
-61 dBm при MCS7
-56 dBm при MCS8
-54 dBm при MCS9
HT-80:
-76 dBm при MCS0
-73 dBm при MCS1
-71 dBm при MCS2
-68 dBm при MCS3
-64 dBm при MCS4
-60 dBm при MCS5
-59 dBm при MCS6
-58 dBm при MCS7
-53 dBm при MCS8
-51 dBm при MCS9
Minimum Requirements
• Windows 8/7/Vista/XP SP3, или Mac OS X 10.4 или выше
• Internet Explorer 7, Opera 12.0, Chrome 20.0, Firefox 4.0 or another browser with Java podderžkoj
• Интерфейс Ethernet или Wi-Fi
• Cable or DSL-modem
• Subscribe to a service provider
Functionality
Security
• WPA и WPA2 (Wi-Fi Protected Access)
• WPS (Wi-Fi Protected Setup)
Advanced Functions
• Web-setup wizard
• QoS (Quality of Service)
• DMZ (Demilitarized Zone)
• Межсетевой экран - Network Address Translation (NAT)
• Guest Area
• IPv6 ready
Функции mydlink SharePort
• The remote access: access files over the Internet
• The local access: Access your files from any device connected to the DIR-816L
• Supports Web-access to the file SharePort (Web Browser)
  - Access your files from any device connected to the DIR-816L
• Support for USB-drives up to 250 GB
 mydlink Lite
• Remote control
• View information about the current bandwidth of outgoing / incoming connections
• View clients currently connected
• Viewing the browser history for each customer
• Lock / Unlock network access to the client
• Managing the wireless network
• Access through a Web-browser or mobile app for iOS or Android
Support for Mobile Applications
• mydlink Lite
• mydlink SharePort
• QRS Mobile
• Applications support device iPhone®, iPad®, iPod Touch® and Android ™
Physical Properties
Dimensions
151.6 x 112 x 30.5 мм
Weight
204 g
Food
• Input: 100-240 VAC, 50/60 Hz
• Output: 12 V / 1 A
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 65 C
Humidity
• 10% to 90% (without condensation)
•  5% to 95% (without condensation)
Certificates
• IC
• CE
• CSA
• FCC
• C-Tick
Çözümler
Sipariş Bilgisi
Görseller
DIR-816LA1
Back view
Front view
İndir
Destek Merkezi
