DIR-860LEOL EOS
USB 3.0 bağlantı noktası ve mydlink  bulut servis desteği ile AC1200 Dual-Band Kablosuz Gigabit Router
Tanımlama
	Dual-Band Wireless Gigabit Router DIR-860L is equipped with a USB 3.0 port and support cloud service mydlink. Using the latest wireless technology, the router provides an easy connection management and network monitoring. With the support of a cloud service mydlink app and use SharePort Mobile Router allows you to access media content and streaming.
	Fast and reliable home networking
	Dual Band Gigabit Router DIR-860L allows all computers and mobile devices in a single home network with broadband Internet access. Simultaneous dual-band allows for streaming HD-video, make Internet phone calls and browse the internet without delay and from anywhere in your home. Gigabit Ethernet ports provide high-speed wired connection of up to 4 computers or other devices. With its stylish design, ease of use and support for IPv6 this router is ideal for use in networks today and in the future.
	Mydlink service
	The router supports cloud service mydlink, which provides the ability to remotely access, view and control devices from anywhere in your home. The service mydlink you can view information about the users who are connected to the router, change the settings to block unauthorized users from any computer or mobile platforms iOS and Android, connected to the Internet. In addition, parents are available to view and control sites visited by their children.
	Sharing files with one touch
	With the application SharePort Mobile, installed on your mobile device, you can get quick access to documents, movies, pictures and music on USB-drive connected to the router DIR-860L. You can download the music library on the USB-drive and choose to share files from anywhere in the house. You can also view photos on a TV screen, while the rest of the family watching movies on their mobile devices. The user can arrange to stream media files on multiple devices, or download them to your device for later playback offline. The intuitive interface allows any user with quick access to various features and applications that are stored on your drive.
	Technology Wireless AC, providing streaming media content without delay
	Router DIR-860L supports the latest Wireless AC, capable of transmitting data at speeds of up to 1.2 Gbit / s 1 (900AC + 300N).In addition, DIR-860L supports simultaneous dual-band 2.4 GHz and 5 GHz and is equipped with four internal antennas. Working in two ranges allows you to view web-pages, chat with friends and check e-mail, using a frequency of 2.4 GHz, while the frequency of 5 GHz band can be used for streaming media content, online gaming or making Internet calls .
	Easy Installation and Setup
	By the application of QRS (Quick Router Setup) Mobile, installed on a mobile device running iOS or Android, you can quickly and easily perform start-up and remote management of the router. Just plug in the router, open the application and follow a few simple steps to connect without using a computer. In addition, the protection of the network can be configured one-touch WPS.If devices with support for cloud service mydlink you can use the automatic settings Zero Configuration. To do this, simply connect the device with the mydlink enabled cloud service to the DIR-860L, and the router will automatically be added to your account without making any adjustments.
