Hızlı Arama
Ürün Özellikleri:
Kablosuz AC1200 Dual-Band Gigabit Cloud Router
Genel Özellikler:
Fiziksel Özellikler
·         mydlink
·         Wireless standard
o    Wireless AC
·         Wireless speed
o    867 Mbps 5 GHz
o    300 Mbps 2.4 GHz
·         Dual-band
·         WAN type
o    Ethernet
·         Ethernet speed
o    Gigabit
·         Number of Ethernet ports
o    4 ports
·         USB SharePort
·         DLNA server
·         Antennas
o    Internal
Connectivity
·         802.11 a/b/g/n/ac wireless LAN for a complete range of wireless compatibility
·         Multiple internal antennas with Wireless AC technology to optimise your wireless coverage
·         Gigabit WAN and LAN ports for high-speed wired connections
·         USB port to connect storage drives and printers for sharing
mydlink™
·         Remotely view and manage your network over the Internet
·         Access your network through a mobile app
Mobile Apps
·         mydlink™ Lite app helps you access, manage and view your network remotely
·         SharePort™ Mobile app lets you stream and share media files and documents across your network
·         QRS Mobile app sets up your network using a mobile device without the need for a computer
Security
·         WPA & WPA2 wireless encryption protects the network from intruders
·         Wi-Fi Protected Setup (WPS) securely adds devices to your network at the push of a button
Technical Specifications
General
Device Interfaces
·         Four 10/100/1000 Gigabit LAN ports
·         10/100/1000 Gigabit WAN port
·         USB port
Antenna Type
·         2x2 (2.4 GHz) and 2x2 (5 GHz) internal antennas
Standards
·         IEEE 802.11ac (draft)
·         IEEE 802.11n
·         IEEE 802.11g
·         IEEE 802.11b
·         IEEE 802.11a
·         IEEE 802.3
·         IEEE 802.3u
Minimum System Requirements
·         Windows 7/Vista/XP SP3 or
·         Mac OS X 10.4 or higher
·         Microsoft Internet Explorer 6 or higher, Firefox 1.5 or higher, or other Java-enabled browser
·         CD-ROM
·         Ethernet network interface
·         Cable or xDSL modem
·         Subscription with an Internet Service Provider
Functionality
Advanced Features
·         Guest Zone
·         SharePort™ web access
·         Multi-language web setup wizard
·         Green Ethernet
·         DLNA Media server support
·         Dual Active Firewall
o    Network Address Translation (NAT)
o    Stateful Packet Inspection (SPI)
·         VPN passthrough/multi-session PPTP/L2TP/IPSec
mydlink™ Features
·         Remote Management
·         View current upload/download bandwidth
·         View currently connected clients
·         View web browsing history per client
·         Block/unblock client network access
·         Manage wireless network details
·         Accessible through a web browser or iOS or Android mobile app
Mobile App Support
·         mydlink™ Lite
·         SharePort™ Mobile
·         QRS Mobile
Wireless Security
·         WPA & WPA2 (Wi-Fi Protected Access)
·         Wi-Fi Protected Setup (WPS) PIN/PBC
Physical
Dimensions (L x W x D)
·         93 x 116 x 145 mm (3.7 x 4.6 x 5.76 inches)
Weight
·         330 grams (0.73 lbs)
Power
·         Input: 100 to 240 V AC, 50/60 Hz
·         Output: 12 V DC, 2.0 A
Temperature
·         Operating: 0 to 40 °C (32 to 104 °F)
·         Storage: -20 to 65 °C (-4 to 149 °F)
Humidity
·         Operating: 0% to 90% non-condensing
·         Storage: 5% to 95% non-condensing
Certifications
·         FCC Class B
·         CE Class B
·         C-Tick
·         DLNA
·         IPv6 Ready  Wi-Fi Certified
·         Wi-Fi Multimedia (WMM)
·         Compatible with Windows 8
Ürünler | Destek  | Haberler  | Hakkında |
