Hızlı Arama
Ürün Özellikleri:
Wireless Dual-Band N600 Router
Tanımlama:
Wireless Interface
Using a wireless router DIR-815, you can quickly create a high-speed wireless network at home or in the office, providing Internet access to computers and mobile devices almost anywhere (within range of a wireless network). Simultaneous operation in the 2.4 GHz and 5 GHz wireless network allows for a wide range of tasks. The Router can serve as a base station for a wireless network device of the standards 802.11a, 802.11b, 802.11g and 802.11n (at speeds up to 600 Mb / s *).
In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC-address, and allows the use of the WPS, WMM.
Built-in antennas Airgain
The router is equipped with a built-in omni-directional antennas AirGain. Despite its compact size, these antennas are not only not inferior in performance to traditional pin, but in many ways superior to them. With a high gain (4 dBi for the 2.4 GHz, 6 dBi for 5 GHz) and the circular radiation pattern in the horizontal and vertical planes, antenna AirGain work equally well in either direction, provide enhanced wireless coverage and reduce the likelihood of "dead" zones.
4-Port Switch
Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network.
Safety
Wireless Router DIR-815 is equipped with a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network.
Configuration and Management
To manage and configure your wireless router DIR-815 uses a simple and user-friendly web-based interface (available in several languages).
* Up to 300 Mbit / s in the 2.4 GHz and up to 300 Mbit / s in the 5 GHz band
Ürünler | Destek  | Haberler  | Hakkında |
