DIR-300/A/S/D1EOL
Wireless Wireless N 150 Router with Built-in 4-port switch, up to 150 Mbit / s
Nereden Alınır
Tanımlama
Wireless Interface
Using a wireless router DIR-300, you can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to a wireless network from virtually anywhere (in the range of a wireless network). The Router can serve as a base station for a wireless network device of the standards 802.11b, 802.11g and 802.11n (at speeds up to 150 Mbit / s). In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC-address, and allows the use of the WPS, WMM.
4-Port Switch
Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network.
Safety
Wireless Router DIR-300 is equipped with a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network.
Configuration and Management
To manage and configure your wireless router DIR-300 uses a simple and user-friendly web-based interface (available in several languages).
Genel Özellikler
Fiziksel Özellikler
The WAN interface
1 10/100BASE-TX Ethernet port for cable or DSL-modem or a dedicated Ethernet-line
The LAN interface
4 10/100BASE-TX Ethernet port
WLAN interface
• IEEE 802.11n (up to 150 Mbit / s)
• IEEE 802.11b / g
Wireless speed
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11n: from 6.5 to 150 Mbit / s
The output power of the transmitter
• IEEE 802.11b
  17dBm (+ /-1.5dB) at 11,5.5,2 and 1 Mbit / s
• IEEE 802.11g
  17 dBm (+ /-1.5dB) at 6-12 Mbit / s
  16 dBm (+ /-1.5dB) in the 18-24 Mbit / s
  15 dBm (+ /-1.5dB) in the 36-54 Mbit / s
• IEEE 802.11n
  HT20
  + 16.5 dBm (+ /-1.5dB) at MCS0/8-MCS2/10
  + 16 dBm (+ /-1.5dB) at MCS3/11- MCS4/12
  + 15.5 dBm (+ /-1.5dB) at MCS5/13
  + 15 dBm (+ /-1.5dB) at MCS6/14
  + 14 dBm (+ /-1.5dB) at MCS7/15
  HT40
Receiver Sensitivity
• IEEE 802.11b
  -82dBm at 1 Mb / s
  -80dBm at 2 Mbit / s
  -78dBm at 5.5 Mbit / s
  -76dBm at 11 Mbit / s
• IEEE 802.11g
  -85dBm at 6 Mbit / s
  -84dBm at 9 Mbits / s
  -82dBm at 12 Mbit / s
  -80dBm at 18 Mbit / s
  -77dBm at 24 Mbit / s
  -73dBm at 36 Mbit / s
  -69dBm at 48 Mbit / s
  -68dBm at 54 Mbit / s
• IEEE 802.11n
  HT20
  -82dBm at MCS0 / 8
  -79dBm at MCS1 / 9
  -77dBm at MCS2/10
  -74dBm at MCS3/11
  -70dBm at MCS4/12
  -66dBm at MCS5/13
  -65dBm at MCS6/14
  -64dBm at MCS7/15
  HT40
  -79dBm at MCS0 / 8
  -76dBm at MCS1 / 9
  -74dBm at MCS2/10
  -71dBm at MCS3/11
  -67dBm at MCS4/12
  -63dBm at MCS5/13
  -62dBm at MCS6/14
  -61dBm at MCS7/15
Software
Network Features
• The types of WAN-connection:
  ◦ PPPoE
  ◦ Static IP
  ◦ Dynamic IP
  ◦ PPTP/L2TP + Static IP
  ◦ PPTP/L2TP + Dynamic IP
• DHCP-server and DHCP-Client
• DNS relay
• Skip VPN-tunnel (PPTP/L2TP)
• Dynamic DNS
• Static IP-routing
• Remote Access
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• VLAN support
• Flow control (flow control)
• Supports ping from the external network (WAN ping respond)
Wireless connection
• Supports security standards:
  ◦ WEP
  ◦ WPA/WPA2 Personal
  ◦ WPA/WPA2 Enterprise
• MAC-filter
• Control of the connected devices
• Methods and PIN WPS PBC function
• The WMM (Wi-Fi QoS)
• Advanced Settings
• Supports the "client"
Firewall Security
• IP-filters
• MAC-filter
• URL-Filter
• DMZ-zone
• The Prevention of ARP-and DDoS-attacks
• Virtual Servers
• Web-based interface for configuration and management of multiple languages
• Access via TELNET
• Upgrade the firmware of the router through the web-interface
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP-server and manually set the date and time
• The ping
• The traceroute utility
Fiziksel Özellikler
Indicators
• Power
• The Internet
• The wireless network
• 4 LEDs LAN
• WPS
Nutrition
12 V, 0.5A
Measurements
139 x 80 mm
Operating temperature
from 0 to 40 C
Storage temperature
-20 To 65 ° C
Operating humidity
From 10% to 90% non-condensing
Storage humidity
From 5% to 95% non-condensing
Çözümler
Sipariş Bilgisi
Görseller
DIR-300/A/S/D1A/A1
View from the right
Back view
Front view
DIR-300/A/S/D1S/A1
Back view
View from the right
Front view
İndir
Destek Merkezi
