Hızlı Arama
Ürün Özellikleri:
802.11n Wireless Router with built-in 4-port switch and a port USB, with network support 3G/CDMA/WiMAX
EOL
Tanımlama:
Wireless Interface
Using the multifunction wireless router DIR-620, you can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to a wireless network from virtually anywhere (in the range of a wireless network). The Router can serve as a base station for a wireless network device of the standards 802.11b, 802.11g and 802.11n (at speeds up to 300 Mbit / s). In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC-address, and allows the use of the WPS, WMM.
Configuration and Management
To manage and configure a generic wireless router DIR-620 uses a simple and user-friendly web-based interface (available in several languages).
USB-port
The router is equipped with a USB-port for connection of USB-modem with which you can quickly connect to the Internet. In addition, you can connect to USB-port router, USB-drive, which will be used as a network drive, or a printer.
4-Port Switch
Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network.
Safety
Universal Wireless Router DIR-620 is equipped with a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network and access to unwanted websites for users on your local network.
Ürünler | Destek  | Haberler  | Hakkında |
