Hızlı Arama
Ürün Özellikleri:
Broadband Router Ethernet-c 4-port 10/100 Mbit / s, 1 SFP port 10/100 Mbit / s
Tanımlama:
High performance
Broadband Router D-Link DIR-100 is designed for group of users share a broadband Internet connection through a DSL or cable modem. Easy to install and operate, this router is ideal for novice users creating their first networks at home and in small offices.
Quality of Service (QoS)
DIR-100 provides prioritized transmission and reception of VoIP and online traffic to / from the Internet, allowing a group of users a reliable network connection with no traffic delays. QoS support provides broadband access for applications such as Internet telephony, multimedia and games on the Internet.
The high level of network security
Router DIR-100 is equipped with a firewall to protect the computers on the network from DOS attacks and virus attacks.With packet filtering device is based access control ports and MAC / IP-addresses of the source / destination. By using the port forwarding the router can be configured to allow separate FTP, and game servers to share the same Internet-visible IP-address, and at the same time, servers and workstations will remain protected from hackers. Users can set up a home or office Web-site by configuring any of the built-in LAN ports to work as a port DMZ. The parental control feature allows parents and network administrators to filter out unwanted URL-addresses of Web-sites, block domains and control the time of the Internet via a schedule.
Ürünler | Destek  | Haberler  | Hakkında |
