Hızlı Arama
Ürün Özellikleri:
802.11n Wireless Router with Built-in 4-port switch, up to 150 Mbit / s
EOL
Tanımlama:
The device DIR-300NRU is a wireless router with a built-in 4-port switch, which allows you to quickly and easily create a wireless and wired network at home or in the office.
You can connect the wireless router DIR-300NRU to a cable or DSL-modem or to Ethernet-line and use a high-speed connection to the Internet for a wide range of professional tasks. Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network.
Using a wireless router DIR-300NRU, you can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to a wireless network from virtually anywhere (in the range of a wireless network). The Router can serve as a base station for a wireless network device of the standards 802.11b, 802.11g and 802.11n (at speeds up to 150 Mbit / s).
In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC-address, and allows the use of the WPS, WMM.
Wireless Router DIR-300NRU has a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network and access to unwanted websites for users on your local network.
To manage and configure your wireless router DIR-300NRU use the user-friendly web-based interface (available in several languages).
Ürünler | Destek  | Haberler  | Hakkında |
