DIR-456/C1EOL EOS
Wireless 2.4 GHz (802.11n) router with 3.75G HSUPA networks
Tanımlama
Creating a mobile wireless network
Router D-Link 3.75G HSUPA networks, users can access anywhere you have mobile broadband network. Once connected, users can transfer data, stream media content, and make mobile phone calls. To do this, simply insert the SIM-card UMTS / HSUPA and get access to 3G Internet connection through a secure wireless network or through any of the three ports 10/100 Fast Ethernet.
Convenient Voice Features
When connected to a 3G network, you can receive and make calls from the phone connected to the router using a standard RJ-11 connector. Functional WAN port and RJ-11 port is planned in future firmware.
Extended wired and wireless security
DIR-456/C1A equipped with double firewall (SPI and NAT) to prevent potential attacks from across the Internet. Protocol support for WPA/WPA2 encryption ensures wireless security
Easy to install and use
HSUPA 3.75G Mobile Router can be quickly and easily installed anywhere. DIR-456/C1A is the ideal solution for situations where a wireless network is to be installed, or wherever conventional network access is not.
