Hızlı Arama
Ürün Özellikleri:
Multimode 5GHz/2.4GHz (802.11a/802.11b) Dual Band Wireless Router with 4 Ports
EOL
Genel Özellikler:
WAN Interface
- 1 RJ-45 10BASE-T/100BASE-TX port for DSL/cable modem connection
- Supports PPPoE, PPPoA for dial-up DSL connection to save ISP char ge
LAN Interfaces
- Built-in 802.11a/b+ wireless LAN
- Built-in 4-port 10BASE-T/100BASE-TX 10/100Mbps switch
Memory
- SDRAM: 2MB
- Flash memory: 512KB
RFC Support
- RFC 0768 User Datagram Protocol
- RFC 0791 Internet Protocol
- RFC 0792 Internet Control Message Protocol
- RFC 0793 Transmission Control Protocol
- RFC 0821 Simple Mail Transfer Protocol
- RFC 0826 Ethernet Address Resolution Protocol
- RFC 1058 Routing Information Protocol
- RFC 1112 IGMP v1 (for UPNP  and IAPP functions)
- RFC 1157 Simple Network Management Protocol
- RFC 1213 Management Information Base-II (MIB II)
- RFC 1332 PPP Internet Control Protocol
- RFC 1350 TFTP Protocol (Reversion 2)
- RFC 1514 Dynamic Host Configuration Protocol
- RFC 1631 IP Network Address Translator
- RFC 1661 Point-to-Point Protocol (PPP)
- RFC 1723 RIP-2 Carrying Additional Information
- RFC 1945 Hypertext Transfer Protocol HTTP/1.1 (subset)
- RFC 1994 PPP Challenge Handshake Authentication Protocol (CHAP)
- RFC 2132 DHCP Options and BOOTP vender Extensions
- RFC 2516 PPP Over Ethernet (PPPoE)
IP Number Self-identification
Through DHCP client
Router
Built-in Wireless LAN
Configuration & Management
- Web-based configuration
- Telnet configuration
- SNMP agent with built-in MIB-II
- Network Time Protocol (NTP) support
- UPnP support
- Factory reset (through reset button)
Firmware Upgrade
Through TFTP
Router
Routed Packet Type
IP packets
Routing Protocols & Methods
- RIP-1, RIP-2
- Static Routing
- Dynamic Routing
VPN Support
IPSec pass-through
Internet Gateway Functions
- Network Address Translation (NA T)
- DHCP server (for automatic IP assignment)
Number of Virtual Server Mappings
10 entries
Standards
802.11a/b+
Frequency Range
- 802.11a: 5.15 - 5.35 GHz
- 802.11b+: 2.4 - 2.4835 GHz
Data Rates
- 802.11a: up to 54Mbps
- 802.11b+: up to 22Mbps
Antennas
- 1 5dBi Gain dipole fixed external antenna for 5GHz transmission
- 1 embedded antenna for 5GHz transmission
- 1 2dBi Gain dipole fixed external antenna for 2.4GHz transmission
- 1 embedded antenna for 2.4GHz transmission
RF Transmit Output Power
- 802.11a: 14 - 17 dBm
- 802.11b+: 16 - 18 dBm
Operating Range
- Up to 100 m (328 feet) indoors
- Up to 400 m (1,312 feet) outdoors
Security
- 802.11a data encryption: 64-bit, 128-bit, 152-bit WEP
- 802.11b+ data encryption: 64-bit, 128-bit, 256-bit WEP
- User-definable node access control list
Built-in Fast Ethernet Switch
Number of Ports
4 10/100Mbps switch ports
Standards
- IEEE 802.3 10BASE-T Ethernet
- IEEE 802.3u 100BASE-TX Fast Ethernet
- ANSI/IEEE 802.3 NWay auto-negotiation
Supported Functions
- Full/half duplex (per port)
- MDI-II/MDI-X auto uplink (per port)
- Auto correction of twisted-pair Rx reverse polarity (per port)
Flow Control
- IEEE 802.3x Flow Control in full-duplex
- Back pressure in half-duplex
Transmission Method
Store-and-forward
MAC Address Learning
Automatic update
Fiziksel Özellikler
Diagnostic LEDs
- Power (status)
- M1 (system ready)
- M2 (system initial/backup/firmware download)
- WAN (Link/Activity)
- 802.11a WLAN (status)
- 802.11b WLAN (status)
- 1, 2, 3, 4 LAN ports (Link/Activity)
Power Input
- DC 5V 3A
- Through external AC power adapter
Dimensions
235 x 161 x 35 mm
Weight
810 grams
Operating Temperature
0 - 55  C
Humidity
95% maximum non-condensing
EMI Certification
- FCC Class B
- CE Class B
Safety Certification
- UL
Compatibility
Wi-Fi
Storage Temperature
-20  -  65  C
Ürünler | Destek  | Haberler  | Hakkında |
