DIR-620EOL EOS
Tanımlama
	Creating a wireless network and access to network 3G/CDMA/WiMAX
	Wireless Router 802.11n DIR-620 allows you to create a wireless network at home and office. By connecting a wireless router to a leased line or a broadband modem, users can share a high-speed connection to the Internet to find information on the Web, check e-mail and communicate with friends and family in online, as well as use the built-torrent client to download various files. DIR-620 is equipped with a USB port for connecting 3G/CDMA/WiMAX * adapter that allows users to access anywhere there 3G/CDMA / WiMAX network. The device supports wireless connection at speeds up to 300 Mbit / s 802.11n standard and is backward compatible with the devices standard 802.11b / g.
Securing Your
	Wireless Router DIR-620 has a built-in firewall that safeguards your network from harmful attacks. It minimizes the threats of hackers and prevents unwanted intruders from entering the network. Additional security features, such as MAC address filtering, to prevent unauthorized access to the network. The "Parental Control" allows you to prevent users from viewing inappropriate content. 802.11n Wireless Router also supports encryption standards WEP (128/152-bit), WPA, WPA2. Due to the supported routing functionality and security, wireless router D-Link DIR-620 allows you to create a wireless network for your home or office.
The list of supported 3G USB modems
- Huawei E150
- Huawei E160G
- Huawei E169G
- Huawei E220
- Huawei E1550
- ZTE MF626
- ZTE MF627
- AnyData ADU-300A
