DI-106MWEOL EOS
ISDN U interface, IP/IPX routing, bridging
Nereden Alınır
Tanımlama
High-Speed Remote Link
The router provides 1 BRI with 2 channels, each transmitting at 64Kbps. With data compression, transmission can be at up to 512Kbps, giving the SOHO or branch office the ideal high-speed WAN link.
Network Address Translator (NAT)
The router comes with Network Address Translator (NAT) which allows the network to support a large number of users from a single shared IP address for cost savings and enhanced security.
Robust Security Features
Many security features are added to provide a secured network environment. Features such as passwords for the system management terminal, PAP, CHAP, MS-CHAP protocols for remote access users, and firewall filtering for access control are provided. Up to 8 passwords protect accounts for remote administrators. RADIUS provides a solution to centralizing authentication for remote access.
Remote User Support
The router provides remote network access through ISDN. This allows for 2 users to login simultaneously from 2 different locations.
Built-in Ethernet Hub
The router has 6 Ethernet hub ports built into it to provide SOHO users with an all-in-one solution for Internet connection. The built-in hub feature saves users the time and trouble of purchasing and
installing a separate hub by allowing 6 separate workstations to directly connect to the router.
Internet Tool Kit
The router comes with a kit containing powerful and useful tools to access the Internet and related documents. Included in this kit are a Web Configurator, Java Activator, Microsoft Internet Explorer 4.x, Netscape Communicator 4.x, Navigator 4.x, WinZip 6.3, WS_FTP, NetInfo 2.1 and Acrobat Reader 3.0.
Genel Özellikler
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DI-106MW
Front view
İndir
Destek Merkezi
