DMC-F20SC-BXU
Media converter (TX: 1310nm, RX: 1550nm) 100BASE-TX twisted-pair 100BASE-FX single-mode Fiber (20km, SC)
Nereden Alınır
Tanımlama
Media Converter DMC-F20SC-BXD and DMC-F20SC-BXU perform the conversion interfaces "twisted pair - single-mode fiber over a single fiber" networks Ethernet 10/100BASE-TX and 100BASE-FX. The devices can simultaneously transmit and receive signals at 1310 nm and 1550 nm on a single optical fiber for distances up to 20 km.
Media Converter DMC-F20SC-BXD and DMC-F20SC-BXU have 1 port RJ-45 twisted-pair port and 1 optical cable (SC-connector).On the twisted pair port supports automatic speed detection modes (full-duplex or half-duplex), the polarity of MDI / MDI-X, which simplifies installation media converter in the existing network. The converter supports management functions such as LLCF (Link Loss Carry Forward, Link Pass Through) and LLR (Link Loss Return) for the port FX.
Genel Özellikler
Fiziksel Özellikler
Interfaces
• Port 10/100BASE-TX
• Port 100BASE-FX Single Fiber FX (plug SC)
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX, 100BASE-FX
Wavelength
TX: 1310, RX: 1550, 20 km
Transfer rate
148,800 pps max.
Indicators
Power, Link / Act / Speed
The physical parameters
Nutrition
Switching Power Adapter 5V/1A
Power consumption
• Power on. (Standby): 0.97 W
• Power Input: 1.57 W DC
• Maximum power input:
  - AC: 1.44 W
  - Constant: 2.18 W
Heat release
• Power on. (Standby) with a variable power input 5.36 BTU / h
• Max.: 7.44 BTU / h
MTBF
482.583 h
Measurements
70 x 95 x 25 mm
Operating temperature
0 C ~ 50 º C
Storage temperature
-10 ~ 70 ° C
Humidity
• Operating: 10% ~ 90%
• Storage: 5% ~ 90%
Certifications
• EMI: CE class A, FCC class A, VCCI class A, BSMI class A
• Safety: LVD, UL / cUL
Çözümler
Sipariş Bilgisi
Görseller
DMC-F20SC-BXU
Front view
Back view
İndir
Destek Merkezi
