DAS-4672-40Proje
POTS Splitter Card, 48 ports
Nereden Alınır
Tanımlama
POTS Splitter Module. This module supports 48 ports for connecting analog telephones with two RJ-21 connectors and 48-port ADSL c two RJ-21 connectors. This allows service providers to ensure the integration of infrastructure PSTN and ADSL.
Genel Özellikler
Fiziksel Özellikler
Interfaces
2 x RJ-21 LINE, 2 x RJ-21 POTS
The physical parameters
Measurements
• Height: 400 mm
• Width: 24.1 mm
• Depth: 255.1 mm
Weight
1.9 kg
Çözümler
Sipariş Bilgisi
Görseller
DAS-4672-40
Front view
İndir
Destek Merkezi
