DSL-224
Wireless N300 VDSL2 Router with ADSL2+/Ethernet WAN Support
Tanımlama
DSL Port and 4-port Switch, Ethernet WAN Support
The router is equipped with a DSL port to connect to a high-speed VDSL line. The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network. In addition, any Ethernet port of the device can be used to connect to a private Ethernet line.
Wireless Interface
Using the DSL-224 device, you are able to quickly create a wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n.
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Security
The wireless router DSL-224 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy configuration and update
You can configure the settings of the wireless router DSL-224 via the user-friendly web-based interface (the interface is available in several languages).
The fast and easy configuration wizard allows you to specify all needed parameters in several simple steps.
Also DSL-224 supports configuration and management via mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
Genel Özellikler
				 Hardware
				 Processor
				 • RTL8685S (500MHz)
				 RAM
				 • 32MB, DDR2 SDRAM
				 Flash
				 • 8MB, SPI
				 Interfaces
				 • RJ-11 DSL port
				• 4 10/100BASE-TX LAN ports
				 LEDs
				 • Power
				• Internet
				• DSL
				• 4 LAN LEDs
				• WLAN
				• WPS
				 Buttons
				 • POWER button to power on/power off
				• RESET button to restore factory default settings
				• WPS button to set up wireless connection
				• WIFI button to enable/disable wireless network
				 Antenna
				 • Two external non-detachable omnidirectional antennas (5dBi gain)
				 MIMO
				 • 2 x 2
				 Power connector
				 • Power input connector (DC)
				 Installation
				 • Desktop
				• Wall
				 DSL Parameters
				 VDSL/ADSL Standards
				 • VDSL2: ITU G.993.2, support of 8a, 8b, 8c, 8d, 12a, 12b, 17a, 30a profiles
				• ADSL: Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs)
				• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
				• ADSL2+: ITU-T G.992.5 Annex A/L/M
				 ATM/PPP Protocols
				 • Bridged and routed Ethernet encapsulation
				• VC-based or LLC-based multiplexing
				• ATM Forum UNI3.1/4.0 PVC (up to 8 PVCs)
				• ATM Adaptation Layer Type 5 (AAL5)
				• ITU-T I.610 OAM F4/F5 loopback
				• ATM QoS
				• PPP over ATM (RFC 2364)
				• PPP over Ethernet (PPPoE)
				• Keep-alive for PPP connections
				 Software
				 WAN connection types
				 • PPPoA
				• PPPoE
				• IPv6 PPPoE
				• PPPoE Dual Stack
				• IPoA
				• Static IPv4 / Dynamic IPv4
				• Static IPv6 / Dynamic IPv6
				• Bridge
				 Network functions
				 • DHCP server/relay
				• Advanced configuration of built-in DHCP server
				• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				• DNS relay
				• Dynamic DNS
				• Static IPv4/IPv6 routing
				• IGMP Proxy
				• IGMP snooping
				• RIP
				• Support of UPnP IGD
				• Support of VLAN
				• WAN ping respond
				• Support of SIP ALG
				• Support of RTSP
				• LAN/WAN conversion
				 Firewall functions
				• IPv4/IPv6 filter
				• MAC filter
				• URL filter
				• DMZ
				• Virtual servers
				 VPN
				 QoS
				 • Interface grouping
				• VLAN priority (802.1p)
				 Management and monitoring
				 • Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
				• Multilingual web-based interface for configuration and management
				• Support of D-Link Assistant application for Android smartphones
				• Support of logging to remote host
				• Ping utility
				• Traceroute utility
				• TR-069 client
				 Wireless Module Parameters
				 Standards
				 • IEEE 802.11b/g/n
				 Frequency range
The frequency range depends upon the radio frequency regulations applied in your country
				 • 2400 ~ 2483.5MHz
				 Wireless connection security
				 • WEP
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • WMM (Wi-Fi QoS)
				• Information on connected Wi-Fi clients
				• Advanced settings
				• Smart adjustment of Wi-Fi clients
				• Guest Wi-Fi / support of MBSSID
				• Limitation of wireless network rate
				• Periodic scan of channels, automatic switch to least loaded channel
				• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				 Wireless connection rate
				 • IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
				 Transmitter output power
				 • Less than 20dBm (100mW)
				 Receiver sensitivity
				 • 802.11b
				  - 86dBm
				• 802.11g
				  - 72dBm
				• 802.11n
				HT20
				  - 67dBm
				HT40
				  - 65dBm
				 Modulation schemes
				 • 802.11b: CCK (11, 5.5Mbps), DQPSK (2Mbps), DBPSK (1Mbps), DSSS
				• 802.11g: PSK/CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK, 16QAM, 64QAM
				• 802.11n: PSK/CCK, DBPSK, DQPSK, OFDM, etc.
				 Physical Parameters
				 Dimensions (L x W x H)
				 • 205 x 139 x 32 mm (8 x 5.5 x 1.3 in)
				 Weight
				 • 260 g (0.6 lb)
				 Operating Environment
				 Power
				 • Output: 12V DC, 1A
				 Temperature
				 • Operating: from 0 to 40 °C
				• Storage: from -20 to 70 °C
				 Humidity
				 • From 5% to 95% (non-condensing)
| Delivery Package | |
				 • Router  DSL-224
				• Power adapter DC 12V/1A
				• RJ-11 telephone cable
				• Ethernet cable
				• Splitter
Çözümler
Sipariş Bilgisi
DSL-224/R1  Wireless N300 VDSL2 Router with ADSL2+/Ethernet WAN Support
