SP-206E
ADSL2+ Annex B splitter with 10 cm phone cable
Nereden Alınır
Tanımlama
The SP-206E splitter is a low frequency filter and it is intended for dividing low frequency telephony signal (voice signal spectrum) and high frequency ADSL signal. The SP-206E is placed at the phone line input (before phone connection). Thus, using the splitter excludes interference of modem and phone signals, providing concurrent operation of the devices. This splitter is equipped with the elements protecting the device against impulse over voltage and crosstalk. ADSL, ADSL2, ADSL2+ Annex B standards are supported.
Genel Özellikler
Interfaces
• One RJ-11 connector for a phone line
• One RJ-11 connector for a phone (or mini-PBX)
• One RJ-11 connector for a ADSL modem
Standards
• ADSL, ADSL2, ADSL2+ Annex B
Dimensions (L x W x H)
• 60 x 44 x 23.5 mm
Operating temperature
• 5 to 40 °C
Storage temperature
• -20 to 85 °C
Operating humidity
• 5% to 85%
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
SP-206E  ADSL2+ Annex B splitter with 10 cm phone cable
Görseller
SP-206E
View from the right
Back view
Вид сверху
Вид снизу
Front view
İndir
Destek Merkezi
