Hızlı Arama
Ürün Özellikleri:
24-Port IP DSLAM 2 combo ports 10/100 / 1000Base-T / SFP
Genel Özellikler:
Fiziksel Özellikler
Features:
Device Interfaces
+ Connector cable RJ-45 - RS-232 DB type of "mother"
+ Gigabit Ethernet port for external control
Network Uplink-interfaces
+ 2x combo ports: 10/100/1000 Base-T or mini-GBIC
ADSL Standards
+ ANSI T1.413
+ ITU-T G.992.1, (G.dmt) Annex A
+ ITU-T G.992.2, (G.lite) Annex A
+ ITU-T G.992.3 (ADSL2)
+ ITU-T G.992.3 Annex L (RE-DSL)
+ ITU-T G.992.5 (ADSL2 +)
+ ITU-T G.992.5 (Annex M)
Throughput
+ Network uplink-interface - the network uplink-interface: 1Gbit / s per port
+ Network uplink-interface - ADSL-access interface: maksmum 28Mbit / s (Downstream), 2,8Mbit / s (Upstream with AnnexM)
User Interfaces ADSL
+ 24 ports (one connector Line RJ-21, 1 POTS RJ-21 connector on the front panel)
Alarm I / O
+ 4 Input Alarm
+ 1 Output Alarm
ADSL-speed transmission of data
+ Upstream from 32 kbit / s up to 2800 kbit / s in increments of 32 kbit / s
+ Downstream from 64 kbit / s to 28000 Kbit / s in increments of 32 kbit / s
ATM protocol
+ Ethernet over ATM (RFC 1483 bridged)
+ IPoA (RFC 1483 routed)
+ PPPoA (RFC 2364)
+ PPPoE (RFC 2516)
Certifications
+ CE, EN 55022 Class A / CISPR 22, CB Report, IEC60950-1, RoHS Directive
Diagnostic Lights
+ Alarm, power, DSL-status
System control
+ Track the status and emergency situations
- Automatic alarm and reports the status change system
+ Performance Monitoring
- Line speed transmission
- Monitoring bandwidth
- Collection of performance parameters ADSL-line in accordance with the RFC 2662 / RFC 3440
- Supports ICMP ping test
+ Setting
- Add, delete, query and change settings functions
- Setting IGMP snooping
- Configure VLAN
- Setting STP / RSTP
- Manage subscriber line ADSL through configuring Profile
- Updating and downloading software via TFTP
- BOOTP / DHCP-Client
+ Safety
- Ensuring the safety and support of the two levels of privileges to log on
VLAN
+ IEEE 802.1Q VLAN Tagging, VLAN based on ports and GVRP
+ Simultaneous support for VLAN 512
+ IEEE 802.1ad VLAN stacking and VLAN translation
Link Aggregation
+ Static and dynamic 802.3ad Link Aggregation
Quality of service (QoS)
+ IEEE 802.1p (8 priority queues)
+ DiffServ
+ Packet classification based on MAC / IP-address and TCP / UDP port
Multicasting
+ Support for IGMP Snooping on the basis of protocols IGMPv1, IGMPv2 and IGMPv3
+ Up to 256 multicast groups and 256 copies on the device
Broadcast Storm Control +
Bridge mode
4 + K MAC-addresses
Filtration + MAC / IP-addresses and TCP / UDP-ports
+ Support agents DHCP / PPPoE intermediate (relay)
+ Option 82, Circuit ID and Remote ID
+ IPOA-to-IPOE internetworking
+ PPPoA-to-PPPoE internetworking
Diagnosis, OAM, and access control
+ Diagnostic Protocol DELT
+ Limit the number of MAC addresses ADSL-customers
Diagnosis + ICMP Ping
Diagnosis + ATM OAM F5
Network control
+ Command Line Interface CLI via console or Telnet
+ SNMP v1 / v2c
+ Web-Management
+ Set up, troubleshooting, performance, security management
+ Support for NMS
Software
System control
+ Setting
- Configure VLAN
+ Safety
VLAN
Link Aggregation
+ DiffServ
Multicasting
Bridge mode
4 + K MAC-addresses
Network control
+ SNMP v1 / v2c
+ Web-Management
+ Support for NMS
MIB Management
+ RFC 1157 SNMP v1
+ SNMP v2c
+ RFC 1213 MIB-II
+ RFC 1493 Bridge MIB
+ RFC 2233 IF-MIB
+ RFC 2515 ATM MIB
+ RFC 2674 802.1Q MIB
+ RFC 2622 / RFC 3440 ADSL line MIB
+ Enterprise DAS3248 MIB
Nutrition
100-240 VAC, 47-63 Hz
Dimensions
+ 449.58 x 320 x 49,78 mm
Width
+ 19 inch or 23 inch mounting kit ("ears»), 1,2U
Temperature
+ Operating temperature: -40 ° ~ 65 ° C
+ Storage Temperature: -40 ° ~ 70 ° C
Humidity
+ 5% to 95%, non-condensing
Ürünler | Destek  | Haberler  | Hakkında |
